Sparkplug look
Sparkplug look
check my sparkplug out. Whats the problem here? too rich to lean.....?
The pic is kinda blurry but check it out
http://i46.photobucket.com/alb...g.jpg
Re: Sparkplug look (hondachris1994)
Its so blurry....but the fact that the tip is so white, you are running lean. It needs more fuel until the porselin looks light brown.
Re: Sparkplug look (Marauder)
Its fine unless you pulled the plug after a full throttle pass. Hondas run lean at idle. That is not that white. When I pulled mine a few months back it was like that. I searched on here quite a bit, and was able to find others who had the same plug color and were fine. On here somewhere is a chart that shows what a plug that is to hot look like, it will be all blistery and skinny. Yours looks fine, to get that brownish/tanish color from a Civic you would almost need some type of fuel managment system.
Re: Sparkplug look (turner7205)
[QUOTE= Yours looks fine, to get that brownish/tanish color from a Civic you would almost need some type of fuel managment system.[/QUOTE]Is this correct? anyone
couldnt tell ya. its hard to see. and i dont know much about plugs. ill go to class today and see what the chart on the wall says. in the meentime try and get me a clear picture.
i have bosch plat 4's in my car. i think i put them in in december. mainly because my car will idel ruff in the cold. now there jet black, and they have a lot of carbon buildup on them. i mean like chunky. so i filled up on 94octane and put some lucas injector cleaner through my tank. and right away my car willl softly in the morning.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turner7205 »</TD></TR><TR><TD CLASS="quote"> Hondas run lean at idle. That is not that white. When I pulled mine a few months back it was like that. I searched on here quite a bit, and was able to find others who had the same plug color and were fine. On here somewhere is a chart that shows what a plug that is to hot look like, it will be all blistery and skinny. Yours looks fine, to get that brownish/tanish color from a Civic you would almost need some type of fuel managment system.</TD></TR></TABLE>Anyone else know somethin.Can I fix this problem with a adjustable fuel regulator?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondachris1994 »</TD></TR><TR><TD CLASS="quote">Anyone else know somethin.Can I fix this problem with a adjustable fuel regulator?</TD></TR></TABLE>
It's really not a problem. My plugs have always looked like that. Hondas tend to run a bit lean.
