81.5mm bore, what head gasket do i use?
Old Mar 7, 2006 | 08:07 PM
Master23's Avatar
Default 81.5mm bore, what head gasket do i use?
I have a cylinder wall bored to 81.5mm and pistons 81.5mm overbore, what kind of gasket should i be using? Will OEM b16 head gasket work fine?
Old Mar 8, 2006 | 09:47 AM
Master23's Avatar
Default Re: 81.5mm bore, what head gasket do i use? (Master23)
bump
Old Mar 8, 2006 | 09:49 AM
tayhas's Avatar
i am running 85 mm bore and i use a cometic gasket.
Old Mar 8, 2006 | 11:11 AM
sleepencivic's Avatar
Default Re: 81.5mm bore, what head gasket do i use? (tayhas)
yea oem works fine(stock bore)....that is your only option
Old Mar 8, 2006 | 11:19 AM
mike1114's Avatar
Default Re: 81.5mm bore, what head gasket do i use? (sleepencivic)
Golden eagle sells headgaskets of various bores up to 84mm.
BUt an OEM one will be fine for 81.5.
Old Mar 8, 2006 | 11:36 AM
1bad-eg's Avatar
Default Re: 81.5mm bore, what head gasket do i use? (mike1114)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike1114 &raquo;</TD></TR><TR><TD CLASS="quote">Golden eagle sells headgaskets of various bores up to 84mm.
BUt an OEM one will be fine for 81.5. </TD></TR></TABLE>
Old Mar 8, 2006 | 01:18 PM
Master23's Avatar
Thanks alot guys
panda_eh2
Dec 12, 2007 01:35 PM
eg2oreg6watuwant
13
Oct 24, 2007 09:51 PM
ProPerformance
Jun 16, 2007 08:25 AM
Redvti
Apr 10, 2006 09:45 PM
Bigjussin
11
Apr 16, 2005 02:57 PM
