best tires for low tire wear?
Old Mar 6, 2006 | 07:56 AM
mugen mj5's Avatar
From: Where the shooting range is on the streets of LA, CA.
Default best tires for low tire wear?
hey guys i was wondering what would be the best tires for low tire wear? im going to be needing tires soon so i wanted to know your opinions from past to present tire experiences... thanks in advance...
Old Mar 6, 2006 | 08:01 AM
DaveSi677's Avatar
Default Re: best tires for low tire wear? (mugen mj5)
i would go with es100 or kumho SPT
Old Mar 6, 2006 | 08:15 AM
mugen mj5's Avatar
Default Re: best tires for low tire wear? (93SiVtec677)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93SiVtec677 &raquo;</TD></TR><TR><TD CLASS="quote">i would go with es100 or kumho SPT</TD></TR></TABLE>
yah i was thinkin those 2 exact type of tires... but which one do u think last more?
Old Mar 6, 2006 | 08:18 AM
hondapowa's Avatar
general tire wear or camber wear?
Nitto Neo-Gen tires are awesome to combat camber wear and pretty much any good brand Z rated tire is for all around protection....
Old Mar 6, 2006 | 08:23 AM
DaveSi677's Avatar
Default Re: (hondapowa)
the best advice I could give you is go to the tire section and ask nsxtasy he will give you more details on what to look for. He nearly had every tire so he know his stuff.
Also the SPT is a little cheaper then the Es100 but just as good.
Dave
Old Mar 6, 2006 | 09:20 AM
old man neri's Avatar
Default Re: (93SiVtec677)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93SiVtec677 &raquo;</TD></TR><TR><TD CLASS="quote">the best advice I could give you is go to the tire section and ask nsxtasy he will give you more details on what to look for. He nearly had every tire so he know his stuff.
Dave</TD></TR></TABLE>
You mean there is tire help in the tire forum?????
also answer these 6 questions when you post there.
1) what is the make/model/year/package of car you have and are there any mods.
2) what is your budget
3) what size rims do you have (include offset if you have it)
4) what is the climate that these tires will see? If you live in a snowy area do you have dedicated winter tires
5) what is the purpose of this car? Drag strip? Auto-X? Getting groceries? Daily driver with weekend play?
6) what is your budget and what is more important long life or stickyness?
Cheers.
Old Mar 6, 2006 | 09:24 AM
dohcdelsol's Avatar
For normal everday driving, non snow tires, i've had my yoko es100's for a good year with a little aggresive driving. They still are holding up and passed PA inspection just recently.
They are also great in wet weather which i wasnt exspecting. BUT THEY SUCK IN SNOW!!!!! obviously.
And for 195-55-15, 63.00 a tire isnt bad at all
just my .02
Old Mar 6, 2006 | 09:55 AM
riceburnerryan's Avatar
also, there is a big tire guide in the super street this month ... its pretty good
Old Mar 6, 2006 | 10:02 AM
FalkenSiR's Avatar
Default Re: (riceburnerryan)
Goodyear Assurance. Threadwear is 760
And you can't go wrong with a goodyear tire, you have proven performance (not aggressive), warranty, and they'll last a long time. I've seen them in quite a few cars (not from factor of course). I am supposing you are not looking for a sporty/performance oriented tire, because this is not it.
Old Mar 6, 2006 | 10:05 AM
Default Re: (fast88std)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast88std &raquo;</TD></TR><TR><TD CLASS="quote">Goodyear Assurance. Threadwear is 760
You can't compare treadware ratings between different manufacturers. I don't think you can even compare it between different tire models. What you can compare is what they warrenty or gurarentee the tire for. That should be a good indication of tread longevity.
Old Mar 6, 2006 | 10:19 AM
FalkenSiR's Avatar
Default Re: (old man neri)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by old man neri &raquo;</TD></TR><TR><TD CLASS="quote">
You can't compare treadware ratings between different manufacturers. I don't think you can even compare it between different tire models. What you can compare is what they warrenty or gurarentee the tire for. That should be a good indication of tread longevity.</TD></TR></TABLE>
That is when his research comes in handy
Old Mar 6, 2006 | 10:37 AM
That is when his research comes in handy </TD></TR></TABLE>
Indeed. One would actually be hard pressed to find a time when research does not come in handy in life.
Cheers.
Old Mar 6, 2006 | 12:55 PM
JSPECSIR's Avatar
nitto neo gen
xkrntamax
Apr 2, 2007 11:56 PM
torqueless
Jan 12, 2005 08:47 PM
vdub08
Jan 3, 2005 08:27 PM
SOHCMAN
Jan 15, 2004 08:11 AM
preluder
Apr 21, 2003 09:19 AM
