a little issue with my turbo help me out please!!!
Old Mar 5, 2006 | 12:56 PM
booja's Avatar
Default a little issue with my turbo help me out please!!!
well i took my pipes off and compreoor housing off to clean cuz there was crap inside (ran no filter and just a screen for like 2 months)
well i was putting everything back together and everything was going good not problems
then i ws putting on my compressor housing last... got it on the turbo and all, put those brackets back on and i hand tightened all of the bolts to make sure i dont strip them...
everything was going down smooth... got a wrech and started to tighten them all down slowly
well i got all of them tight on one bracket... but the other bracket the middle one is just hand tight but the others are real tight
it was going down and tightening up then suddenly it got loose again... i already knew what happened... so i took it out and i can see the threads on the bolt from what the turbo left behind...
so now it just spins and doesnt tighten.... is there a way i can fix this or just leave it like that... is the compressor sealed enough... being that its the middle one and the rest are tight
Old Mar 5, 2006 | 01:07 PM
booja's Avatar
this bolt here, but the rest are tight
Old Mar 5, 2006 | 01:16 PM
TEG777's Avatar
you could re- thread the hole, but i think you should be ok as is
Old Mar 5, 2006 | 01:18 PM
booja's Avatar
yeah i figured it would be ok seeing that all the rest are tight and its the middle one so the ones around it should be holdin it down...
i haven driven it yet to see if itll boost all the way up...
i was just concerned since i just got done putting it back together
Old Mar 5, 2006 | 04:07 PM
EARLdaSQUIRREL's Avatar
official honda whore
Default Re: a little issue with my turbo help me out please!!! (booja)
just heli-coil it and forget about it, i mean why do a hack job when heli-coils are cheap and easy to do
Old Mar 5, 2006 | 07:18 PM
booja's Avatar
yeah i suppose i could, but would it hold the way it is now... thats what i really wanna know...
otherwise i gotta take the housing off and redo and tap it and heli coil it and all that
Old Mar 5, 2006 | 07:37 PM
themorphious's Avatar
Default Re: (booja)
i'd rather be safe than sorry, just my .02 cents
Old Mar 5, 2006 | 11:30 PM
bigdaddyvtec's Avatar
* B A N N E D *
Default Re: (themorphious)
Dude itll be fine... I had a similar issue on a different compressor hopusing....NO problems!!!
Old Mar 6, 2006 | 09:27 AM
booja's Avatar
Default Re: (bigdaddyvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigdaddyvtec &raquo;</TD></TR><TR><TD CLASS="quote">Dude itll be fine... I had a similar issue on a different compressor hopusing....NO problems!!! </TD></TR></TABLE>
cool thanks for lettin me know with actual experience
i appreciate it
Old Mar 6, 2006 | 09:40 AM
AbitAvenger's Avatar
you'd probably be fine, but for a cheap fix, why not?
Old Mar 6, 2006 | 10:43 AM
I Have an STD's Avatar
wrenchin'
Default Re: (AbitAvenger)
i only have 3 of the 6 bolts in my compressor housing, you'll be just fine
lindseyhunt1090
Jun 5, 2015 11:46 AM
patrick4588
Jun 29, 2007 09:33 PM
b18-c-rx
May 18, 2005 11:25 PM
Masta
Nov 16, 2004 12:37 PM
phreakmang
Mar 16, 2004 01:45 PM
