JDM throttle body-HELP!!
Old Mar 5, 2006 | 07:46 AM
QuickDxEk's Avatar
Default JDM throttle body-HELP!!
Ok, My buddy has a 96 civic ex with greddy kit and edelbrock intake. He recently bought a JDM ITR throttle body off of honda-tech. We put installed it and the car idle irrackly and high. I sprayed carb cleaner all over the throttle body and no vaccum leaks were found. The stock throttle body runs normal. PLEASE HELP IF ANYBODY HAS ANY SUGGESTIONS-I suspect something with the TPs so we are running the stock Y8 TPS and it does the same thing!!
Old Mar 5, 2006 | 08:55 AM
jdmeg9's Avatar
Default Re: JDM throttle body-HELP!! (QuickDxEk)
sounds like tps might be shot. or check to see if the tps and map sensor plugs got turned around
Old Mar 5, 2006 | 09:04 AM
QuickDxEk's Avatar
I used both the ITR TPS and the stock Y8 Tps and does the same thing. The car idles at about 1500rpm. When i unplug the tps the idle surges up and down. When i unplug the IACV the car idles down but surges when i rev it. The only time it idle and runs normal is with the stock y8 Tb and tps. It also runs normal when i plug my finger over the IACV hole in the TB. Any more suggestions anyone might have would be great!!
Old Mar 5, 2006 | 10:40 AM
BLKEG6T's Avatar
do have a firewall mounted map ? jdm tb's don't have map sensors. do u have a clip not being used ???
Old Mar 5, 2006 | 10:47 AM
fmrprojects's Avatar
Default Re: (BLKEG6T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLKEG6T &raquo;</TD></TR><TR><TD CLASS="quote">do have a firewall mounted map ? jdm tb's don't have map sensors. do u have a clip not being used ???</TD></TR></TABLE>
jdm itr TB buddy. it has a MAP sensor up top.
check to see if the tps is adjusted correctly. use a volt meter and adjust it to .5 V at closed throttle and 4.5 at wide open throttle
Old Mar 5, 2006 | 11:10 AM
JdmB16Eg6's Avatar
65.115.123.226
dont know if it might fix it but check the idle screw. that might be why it is idling high
Old Mar 5, 2006 | 06:32 PM
Crank's Avatar
Default Re: JDM throttle body-HELP!! (JdmB16Eg6)
check if you put on the gasket the right way.
cmgibby
Jul 24, 2008 12:22 PM
aasaa666
Jun 29, 2008 08:13 PM
dragaholic
Feb 17, 2008 03:09 PM
crfr230
Apr 24, 2007 07:48 PM
Mach69
May 16, 2005 07:02 PM
