H22A Vtec Cut off!! HELP!!!
for some reason my vtec cuts off while it is still kicking it kicks about 5 somthing but then sometimes it cuts off around 6RPM and then it jus redlines at 6.5RPM i dont know wat could be the cause. I have changed the oil, sloved the leaking problem, im not sure if it is my oil pressure switch? ive also flushed my motor, Do u guys think i need a tune up?
The "Why doesn't my VTEC engage thread", from the Prelude forum:
https://honda-tech.com/zerothread?id=830163
Hopefully you can at least narrow the problem down from there.
oh kool thanks man i think i narrowed the problem i have a dented oil pan i think the punk that sold it to me hit sumthing cas its a pretty big dent
Replace the pan or pound the dent out. Your oil pressure could be off b/c of the dent, which in turn would cause the symptoms that you mentioned.
