drive shafts too short???
Old Mar 4, 2006 | 02:25 PM
ezza's Avatar
Default drive shafts too short???
iv just finished my ITR brake conversion, this included the hubs (5 stud bling blang). iv come to put my driveshafts back into the hubs and they seem as if there too short, if the track is 10mm wider thats 5mm wider each side (duh), they come through enough for me to get the nut on, so i thought that i just hadnt put them through properly and tightening the nut would pull them through but it seems as if the nut wont really go any tighter, do i need ITR drive shafts??
Old Mar 4, 2006 | 02:37 PM
dwnthehatch's Avatar
Default Re: drive shafts too short??? (ezza)
Lube the hubs with anti seize. They should slide right in.
Old Mar 4, 2006 | 02:39 PM
ezza's Avatar
Default Re: drive shafts too short??? (dwnthehatch)
so they are the correct length?
EDIT: lol at your avatar
Old Mar 4, 2006 | 03:22 PM
ezza's Avatar
Old Mar 4, 2006 | 04:01 PM
ezza's Avatar
im goin to bed now, please can someone help me, im starting work on it again tomorow
Old Mar 5, 2006 | 12:16 AM
ezza's Avatar
bump
Old Mar 5, 2006 | 03:17 AM
fmrprojects's Avatar
they should fit
Old Mar 5, 2006 | 04:51 AM
ezza's Avatar
Default Re: drive shafts too short??? (fmrprojects)
nah, it looks like the ABS cog thing is stopping it from going into the ITR sindle/hub, can this be removed?
Old Mar 5, 2006 | 08:02 AM
ezza's Avatar
iv found out they are different, the 98+ ITR's had bigger and longer splines, apparently i can just change the outer CV joint for the correct ones (00 ITR in this case), how do i get these off, i have the shafts off and have removed the boots but i cant see how they come off, can anyone help?
Old Mar 5, 2006 | 09:18 AM
ezza's Avatar
please
Aklackner
Nov 19, 2017 02:26 PM
hungpham214
Dec 30, 2006 09:40 AM
ezza
Mar 14, 2006 02:14 PM
BanEL
Feb 17, 2005 09:57 PM
Quik Chris
Apr 12, 2003 06:15 PM
