b18 civic
just wondering if the b18c in a 1995 civic hatch would be as easy an install as a b16?........cant you just use everything from hmotors online full swap to completely convert the enigine, except the vtc wiring?.....including the gsr axles?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by msinsky14 »</TD></TR><TR><TD CLASS="quote">just wondering if the b18c in a 1995 civic hatch would be as easy an install as a b16?........cant you just use everything from hmotors online full swap to completely convert the enigine, except the vtc wiring?.....including the gsr axles?</TD></TR></TABLE>
You may need a wire harness depending on the year of the motor. A b16 will also require wiring for vtec if your hatch didn't come wired for vtec. You will also need to wire a knock sensor.
if you have it all obd1 most of it is pretty straight forward as any other than the vtec and knock sensor, but you also might want to get a chipped ecu and get a basemap that disables the knock sensor to ease the wiring
singleslammer
Aug 3, 2006 10:32 AM
drpepper
Sep 7, 2005 01:53 PM
