How do u remove the Black bezel part from an Integra Cluster?
How do u remove the Black bezel part from an Integra Cluster? .. I already removed the clear plastic.. It just doesnt want to come off..
There are 2 screws at the top of it towards the middle. You kind of have to pry it off because it snaps into a couple things on the bottom. After that there are 3 screws holding the cluster in, 1 on the left, 1 in the middle, and 1 on the right. Also, you did not have to take off the clear plastic as it will come out when you take the cluster out since they are attached together.
As he said above.
Pull the bottom out a little first, and push it downwards a little, that should pop the top off.
Making sure your tilt on the wheel is all the way down helps too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaTeg6 »</TD></TR><TR><TD CLASS="quote">There are 2 screws at the top of it towards the middle. You kind of have to pry it off because it snaps into a couple things on the bottom. After that there are 3 screws holding the cluster in, 1 on the left, 1 in the middle, and 1 on the right. Also, you did not have to take off the clear plastic as it will come out when you take the cluster out since they are attached together.</TD></TR></TABLE>
