cluster removal
Old Nov 24, 2004 | 01:04 PM
TheSquirrel's Avatar
Default cluster removal
Ight i have some burnt bulbs in the cluster of my 94 gsr integra and have bought replacements and just need to know how to remove the cluster to replace them I brefiely searched and couldnt locate it
Old Nov 24, 2004 | 01:52 PM
LSvtec03's Avatar
Default Re: cluster removal (TheSquirrel)
its pretty easy...
1. lower the steering column and remove 2 screws under the top of the bezel.
2. carefully pull the bezel toward you to remove it.
3. now the guage cluster will be exposed. there is one screw on the top center, and one screw on each end. a magnetic tip screwdriver would help so you don't drop the two on the sides.
4. reach behind the cluster and remove the plugs (should be 3 or 4).
now your bulbs will be readily accessible. installation is the reverse of the removal.
Old Nov 24, 2004 | 01:56 PM
.water's Avatar
Default Re: cluster removal (LSvtec03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSvtec03 &raquo;</TD></TR><TR><TD CLASS="quote">its pretty easy...
now your bulbs will be readily accessible. installation is the reverse of the removal.</TD></TR></TABLE>
#2 carefully? well yes..but u need pull that sh@t hard..doesnt come out that easy
Old Nov 24, 2004 | 03:02 PM
BlueIntegraBoy's Avatar
Default Re: cluster removal (Bee8teenSee1)
I find pulling from the bottom is easier
Old Nov 24, 2004 | 03:06 PM
Kendall's Avatar
Default Re: cluster removal (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">I find pulling from the bottom is easier</TD></TR></TABLE>
I'm interested to know how this would work, You do have the steering column to deal with, along with almost no space on either side of the cluster to begin with.
Old Nov 24, 2004 | 03:09 PM
threatcon13's Avatar
New User
Default Re: cluster removal (Kendall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">
I'm interested to know how this would work, You do have the steering column to deal with, along with almost no space on either side of the cluster to begin with.</TD></TR></TABLE> Thats what I was thinking also. I don't see how pulling it from the bottom could work, please enlighten.
Old Nov 24, 2004 | 03:23 PM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: cluster removal (threatcon13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by threatcon13 &raquo;</TD></TR><TR><TD CLASS="quote"> Thats what I was thinking also. I don't see how pulling it from the bottom could work, please enlighten. </TD></TR></TABLE>
If you have tilt then it gives quite a bit of room.
Racermech's Avatar
This is just the plastic trim that we are pulling on, i also found pulling from the bottom was a little easier. I pulled mine apart with out having any idea of how this came apart and I found it pretty easy.
Old Nov 24, 2004 | 03:31 PM
hotsuma23's Avatar
Default Re: cluster removal (Racermech)
Yeah when I pulled my bezel that **** took alot of force to come out. I was afraid to pull too hard cuz I didnt wanna break anything. HAha now I know.
Old Nov 24, 2004 | 07:58 PM
Eight fingers on top of the bottom part and two thumbs between the bottom of the bezel and the column. Pull. At least it works well with EKs. Been a while for me taking out the bezel of an Integra.
Old Nov 25, 2004 | 12:25 PM
LSvtec03's Avatar
i do too, but i just didn't feel like explaining it.
the way i usually do it is to tug the bottom of the bezel out so the clips come out, and then i can squeeze down from the top to get the top loose, and then it comes out easy.
Old Nov 25, 2004 | 12:37 PM
hott-nix's Avatar
http://www.team-integra.net/se...D=313
Old Nov 22, 2006 | 06:26 AM
Swiftstar's Avatar
Default Re: (hott-nix)
So once you get that Bezel wtv thing out, it should be a downward stroll from there?? i also had the same problem when taking that thing out. I stopped because i was affraid of breaking it. i want to install some indiglow's on my 95RS
Old Nov 22, 2006 | 07:40 AM
crxma22's Avatar
Default Re: (Swiftstar)
stock clusters look so much better than indiglo... my experience many many moons ago with those were; the indiglo panels never hold up, so a year or so down the line and your needle will just end up getting caught on it... it left a film that i can't get off my stock cluster and it's bright and distracting after awhile... kinda lights up your face like an alien while driving... just a thought
Old Nov 22, 2006 | 09:03 AM
GuitarSlinger78's Avatar
Default Re: (crxma22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxma22 &raquo;</TD></TR><TR><TD CLASS="quote">stock clusters look so much better than indiglo... my experience many many moons ago with those were; the indiglo panels never hold up, so a year or so down the line and your needle will just end up getting caught on it... it left a film that i can't get off my stock cluster and it's bright and distracting after awhile... kinda lights up your face like an alien while driving... just a thought</TD></TR></TABLE>
Agreed , I was into indiglo's many years ago (don't know why). In my experience the needle/needles will get stuck or one or more of the indiglo faces burn out. I know I liked the look of the white face gauges but at night that thing was soooo bright!
Anyways, taking out the cluster is cake. The harder part is getting off the clear plastic and black pastic off without cracking it. If you take your time your golden. When taking off the clear plastic I always start at the bottom and push up the three tabs then move to the top ones. If you push each one down just enough the entire thing pops right off. If you start and the top then try to work the bottom ones is where I found where it cracks, or breaks the tabs.
The black housing for the gauges, just remember to unscrew the 3 screws that are inset in the back and your good to go. I also wear latex gloves when messing with the gauge cluster because the oil from your hands really sticks to the gauge faces. If you try to use cleaning solvent to wipe it off if streaks and is very noticeable.
Climate control... now that ones a bitch.
Old Nov 22, 2006 | 09:55 AM
Swiftstar's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JoE99Integ &raquo;</TD></TR><TR><TD CLASS="quote">
Climate control... now that ones a bitch. </TD></TR></TABLE>
this guż is Exactly Right. everything he said that might happen DOES.
Modified by Swiftstar at 12:22 PM 11/22/2006
u2civic1
Jan 12, 2010 04:27 PM
Perfectionist
Dec 2, 2006 12:52 PM
tuan...
Oct 27, 2003 04:28 AM
bgod
Dec 17, 2002 12:12 PM
bgod
Dec 17, 2002 10:53 AM
