Integra Cluster Help!!!
Old Jan 6, 2004 | 08:05 PM
vandeec5's Avatar
Default Integra Cluster Help!!!
Im working on my cousin car not very familiar with the integra. How do you take off the Cluster off the integra??
Old Jan 6, 2004 | 08:10 PM
BlueIntegraBoy's Avatar
Default Re: Integra Cluster Help!!! (speedrlcer)
If it's a DC, then take off the two screws on the top of the black bezel. Gently pull from the bottom to take it off. The cluster is held in by three screws, unscrew those. Unplug like 3-4 plugs (forgot how many).
Old Jan 6, 2004 | 10:33 PM
tHeSoCk's Avatar
When I did mine on a 00' gsr I couldn't get it off by gently pulling. I had to give it a pritty hard tug, but be careful not to crack the window
Old Jan 7, 2004 | 02:04 AM
LSvtec03's Avatar
Default Re: (tHeSoCk)
it helps to get out the bezel if you first pull the top out a really small bit (about a cm) then pull out from the bottom. i found this way it would get it out of a little notch or something that made it hard to pull out just from the bottom.
Old Jan 7, 2004 | 05:28 AM
MikeTV
Guest
Posts: n/a
Default Re: (LSvtec03)
Yeah its pretty simple actually......just unscrew the 2 screws on the top of the bezel, and then unscrew the 3 screws holding the cluster down to the frame.....thats it !
slpr_civic93
May 15, 2006 04:45 PM
bzyrice
Mar 4, 2006 12:16 AM
TegLover4life
Apr 19, 2003 12:38 AM
bgod
Dec 17, 2002 12:12 PM
bgod
Dec 17, 2002 10:53 AM
