92 CIVIC HATCH STOCK BREAKS
Old Mar 2, 2006 | 06:30 PM
smokerz212's Avatar
Default 92 CIVIC HATCH STOCK BREAKS
WILL THE SLOTTED DRILLED ROTORS (REPLACE THE STOCK) AND REAR DRUM BREAK CAN HANDLE B16? OR B18? MY CAR IS 92 CIVIC VX. PLS HELP ME WHY YOU NEED TO CHANGE IT. IF IT CAN HANDLE WHY THEY NEED TO CHANGE IT TO GSR BREAKS? COZ IM PLANNING TO SWAP BUT I WANT THE STOCK BREAKS IF I CAN TO SAVE MONEY.
Old Mar 2, 2006 | 06:39 PM
SOHCD16y8's Avatar
What motor you have makes no difference. 50 mph is 50 mphs no matter if you have 100 or 1000 horsepower. Please turn off CAPS LOCK
schardbody's Avatar
who said you HAVE to do anything, the stock brakes are good for the 2100lb car, once you add higher speeds or more weight it becomes an issue. a cheaper solution would be some performance pads, like ebc green pads, work well. or ex/si brakes.
zach0223
24
May 11, 2013 04:06 PM
jxhxb
May 10, 2011 12:27 AM
hapa papa
Suspension & Brakes
Oct 1, 2008 11:26 PM
TruePlayaz114
31
Dec 20, 2002 10:43 AM
SlowB16
10
Mar 19, 2002 05:42 PM
