Mystery plug behind ECU?
Old Mar 2, 2006 | 04:37 PM
JunY's Avatar
Default Mystery plug behind ECU?
It's been always sticking out of the kick pannel so I shoved it back in; I've always been wondering what the blue plug is for? Anyone know?
Old Mar 2, 2006 | 04:39 PM
JDMKid71's Avatar
Default Re: Mystery plug behind ECU? (JunY)
what one the green one or the light grey one?
Old Mar 2, 2006 | 04:42 PM
JunY's Avatar
Default Re: Mystery plug behind ECU? (JDMKid71)
I said "blue." The dead center of picture with two wires sticking out of it, which is not plugged in.
Old Mar 2, 2006 | 04:44 PM
JDMFreak's Avatar
that plug is for checking your check engine light...you can use a wire or a connecter... to make a connection together...and you can use your normal CEL to find out what CEL that you are throwing...(i hope this make sense) .
edit: check this link out https://honda-tech.com/zerothread?id=798020
Old Mar 2, 2006 | 04:46 PM
JunY's Avatar
Default Re: Mystery plug behind ECU? (JDMFreak)
Alright, Thanks for the reply.
Old Mar 2, 2006 | 04:47 PM
JDMKid71's Avatar
my bad skiped over the word "blue" (selective reading) but yeah its the service jumper port. jumper it and your CEL will flash if you have codes.
Old Mar 2, 2006 | 05:40 PM
eXcelonTypeR's Avatar
yup service connector. It goes in the soft green holder right above it in the picture, if you want it out of the way cleanly
Old Mar 2, 2006 | 05:52 PM
ek9child's Avatar
thats the jumper to see what code yur throwig out when the check engine light is on and its for adjusting yur timing
rhoades
10
Dec 28, 2009 12:42 AM
righteyeblind
Jun 30, 2008 01:50 PM
Niskyspy
13
Mar 10, 2008 05:54 PM
SI_niki
Jun 20, 2004 04:04 PM
93EH6
Jan 30, 2003 09:11 PM
