code 7 tps sensor b16
Old Mar 2, 2006 | 04:03 PM
teler86's Avatar
Default code 7 tps sensor b16
hey guys i just swapped in a b16 into my crx and am getting a code 7 tps sensor i know you have to align it and for it to read .5v closed and 4.5wot. but i am not reading that at all i think i hooked up the wrong wires to the tps sensor. i put some pics in there, can you guys tell me the wire colors i have yellow, red/blue, and green/yellow. If you know where these colors go that info would be great too thank you. sorry if im writing in gibberish i'm getting the itch for spring time
btw i just noticed this is my 500th post horray for me
Old Mar 2, 2006 | 04:14 PM
Crx Jimmy's Avatar
Default Re: code 7 tps sensor b16 (teler86)
first off solder the connections and heat shrink wrap the wires, then see if the problem still exists it looks like a mess with all that tape ,
Old Mar 2, 2006 | 04:16 PM
teler86's Avatar
Default Re: code 7 tps sensor b16 (Crx Jimmy)
thats not an issue i just taped it temporarily i am wondering if those are the right colors that go to the sensor.
Old Mar 2, 2006 | 05:04 PM
mar778c's Avatar
Community Builder
Community Influencer
When you extended the tps wires, you swapped the outside two right?
Old Mar 2, 2006 | 05:40 PM
teler86's Avatar
Default Re: code 7 tps sensor b16 (mar778c)
no, should i have? can somebody please go look at their car and tell me what colors the wires are
Old Mar 3, 2006 | 08:32 AM
JDMCivicEF9's Avatar
Yes!
Old Mar 3, 2006 | 11:27 AM
Mach69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teler86 &raquo;</TD></TR><TR><TD CLASS="quote">no, should i have? can somebody please go look at their car and tell me what colors the wires are</TD></TR></TABLE>
If your car was originally DPFI, then you need to switch the two outer wires when you convert to MPFI. Then when you calibrate the tps, make sure you calibrate it with the car turned on a idling. To ~0.45v
Old Mar 3, 2006 | 03:45 PM
teler86's Avatar
Default Re: code 7 tps sensor b16 (Mach69)
well i already had a b16 in there and there was not a code 7 before, but that was obd0 and now i have obd1 would that cause me to need to switch
Touge Tuning
Jul 11, 2016 06:18 PM
beegeezy
Honda CR-V & Element
Aug 18, 2013 02:21 PM
92civicx
Jul 8, 2007 02:57 PM
teler86
Mar 2, 2006 08:10 PM
sLoWrAcEr
10
Apr 24, 2005 03:34 PM
