damned tps sensor
damned tps sensor
i put a new tps on and it still throws the code...could it be the wiring up to the tps? im running a b16 in a 1993 si hatch.....thanx for positive feedback
Re: damned tps sensor (sLoWrAcEr)
what code was it? it should be code 7. any others? Make sure you don't mix the TPS plug with another plug, like the MAP sensor, IAT, etc. I did that with mine. other than that, it has to be the wiring.
Re: damned tps sensor (handa)
has anyone re-did the wiring?.....easy.....hard....? im not good with electronics...should i take it somewhere? only code 7 and it is the right plug
Risky Business
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by handa »</TD></TR><TR><TD CLASS="quote"> Make sure you don't mix the TPS plug with another plug, like the MAP sensor, IAT, etc.</TD></TR></TABLE>
I will second this
I will second this
Waachback
12-02-2003 06:56 PM
