question about ITR tranny
Old Mar 2, 2006 | 01:56 PM
ajwiant's Avatar
Default question about ITR tranny
does it have an overflow hole?
Old Mar 2, 2006 | 08:32 PM
HYREV2NR's Avatar
Default Re: question about ITR tranny (ajwiant)
If i'm not mistaken, yes. Why-whats up?
Old Mar 3, 2006 | 12:16 AM
ajwiant's Avatar
Default Re: question about ITR tranny (HYREV2NR)
my fill plug threads are stripped. im not sure how securely the plug is in there, but my mechanic put a bunch of jb weld around the plug. If i need to refill some fluid, i think i'd rather just fill it from the overflow hole, rather than pull the plug out again.
Old Mar 3, 2006 | 02:44 AM
Asahi's Avatar
Pull the VSS and put it in from the top. Measure carefully though.
Old Mar 3, 2006 | 03:38 AM
typer_696's Avatar
Default Re: question about ITR tranny (Asahi)
Dont be lazy. Go buy a tap and die set. And fix those fucked up threads.
Old Mar 3, 2006 | 04:16 AM
s2kdre's Avatar
Default Re: question about ITR tranny (typer_696)
or u can permanently weld the fill plug shut if u want and just put fluid thru the vss.
Old Mar 3, 2006 | 07:24 AM
HYREV2NR's Avatar
A friend of mine told me about removing the ol' speed sensor & thats the easiest way I think yet.
Old Mar 3, 2006 | 12:11 PM
Circuit Star-29's Avatar
Default Re: (HYREV2NR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmhonda &raquo;</TD></TR><TR><TD CLASS="quote">or u can permanently weld the fill plug shut if u want and just put fluid thru the vss.</TD></TR></TABLE>
How the hell are you gonna change the fluid then? I believe that may be teh stupidest comment/suggestion I've ever read on HT...
Just get a tap set... and torque the nut to the recommended torque amount....
Its aluminum guys...there are torque settings for a reason.
Old Mar 3, 2006 | 12:27 PM
Batoutahell's Avatar
Default Re: (Circuit Star-29)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Circuit Star-29 &raquo;</TD></TR><TR><TD CLASS="quote">How the hell are you gonna change the fluid then? I believe that may be teh stupidest comment/suggestion I've ever read on HT...</TD></TR></TABLE>
I think we all agree that best solution is to tap out the fill plug threads. But, as long as you measure carefully like Trey says, what makes you feel so strongly that it's not possible to change the fluid using the vss?
Old Mar 3, 2006 | 12:29 PM
ajwiant's Avatar
Default Re: (Batoutahell)
if i re tap the threads, is it gonna be secure?
does anyone have pictures of the overflow hole or vss sensor?
Old Mar 3, 2006 | 12:30 PM
p nut's Avatar
I've changed it using both methods (fill hole/vss). Neither is difficult/preferred, but I usually do it through VSS and like the assurity of seeing some fluid come out of the fill hole.
Old Mar 3, 2006 | 12:34 PM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Default Re: (P Nut)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ajwiant &raquo;</TD></TR><TR><TD CLASS="quote">if i re tap the threads, is it gonna be secure?
does anyone have pictures of the overflow hole or vss sensor?</TD></TR></TABLE>
Yes it will be secure. The VSS is the Vehicle Speed Sensor, its on the top, back side of the trans. The wire harness attaches to it.
Old Mar 3, 2006 | 07:00 PM
Asahi's Avatar
Its aluminum guys...there are torque settings for a reason. </TD></TR></TABLE>
You are going to drain it with the drain plug and fill it through the VSS carefully measured. I don't disagree tapping it woudl be preferred but if I recall correctly finding a tap that size is going to prove very challenging.
No arguement torquing it is important but not sure calling people stupid is very concstructive, I've been here a long time and seen a LOT dumber comments and suggestions.
Old Mar 3, 2006 | 10:05 PM
Default Re: (Asahi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Asahi &raquo;</TD></TR><TR><TD CLASS="quote">
No arguement torquing it is important but not sure calling people stupid is very concstructive, I've been here a long time and seen a LOT dumber comments and suggestions.</TD></TR></TABLE>
Didn't call anyone stupid... His suggestion/comment however, was.
I'd like to know how someone might go about draining a tranny from the VSS.
Old Mar 3, 2006 | 10:24 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Circuit Star-29 &raquo;</TD></TR><TR><TD CLASS="quote">Didn't call anyone stupid... His suggestion/comment however, was.I'd like to know how someone might go about draining a tranny from the VSS.</TD></TR></TABLE>
Good grief. Where are you getting the idea that anyone in this thread is suggesting to use the vss to DRAIN the fluid?? It seems you're so busy trying to find fault with others' suggestions that you're absolutely oblivious to the fact that the tranny has a separate DRAIN PLUG. Here it is again in case you missed it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Asahi &raquo;</TD></TR><TR><TD CLASS="quote">You are going to drain it with the drain plug</TD></TR></TABLE>
Old Mar 3, 2006 | 11:11 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Batoutahell &raquo;</TD></TR><TR><TD CLASS="quote">
Chill dood...My apologies...I was under the assumption that the suggestion to WELD THE DRAIN PLUG was the topic here...I retract my statments...
Old Mar 4, 2006 | 08:02 AM
HYREV2NR's Avatar
Uh, it would help if U would read more carefully.
Old Mar 4, 2006 | 03:17 PM
yeah...I kinda got that..
Old Mar 4, 2006 | 08:33 PM
HYREV2NR's Avatar
No prob... All's cool.
Andrew14
21
Jun 28, 2010 01:12 PM
VtecAdvantage
Mar 30, 2010 10:10 PM
jdmcivicracer89
Aug 2, 2007 03:32 PM
invisible
18
Mar 26, 2007 09:08 PM
eL
10
Jan 30, 2005 04:02 PM
