B16a2/b18c into a EK...very quick questions...
Old Mar 2, 2006 | 03:36 AM
bennjamin@ozhonda.com's Avatar
Default B16a2/b18c into a EK...very quick questions...
hi all - search feature brigns back random results so -
I want to install a B18c into a EK civic ~ the B series comes as a halfcut from a SIR integra.
Are all moutns swappable over ? OIR does the EK require EK9/ek4 b series mounts ?
thanks ben
Old Mar 2, 2006 | 04:12 AM
ekb16's Avatar
you would need 99-00 SI driver side bracket mount and rear L bracket..the rest should bolt in
Old Mar 2, 2006 | 10:16 AM
JeffBro's Avatar
Default Re: B16a2/b18c into a EK...very quick questions... (bennjamin@ozhonda.com)
If I were you I would use a hasport mount kit for the drivers side. I did the exact same swap into my ek and I used the Si bracket with the stock mount and the stock mount broke. Use the Si bracket with a hasport kit. All the other mounts have held up so far.
Old Mar 2, 2006 | 10:26 AM
Sl0wEK's Avatar
Default Re: B16a2/b18c into a EK...very quick questions... (JeffBro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JeffBro &raquo;</TD></TR><TR><TD CLASS="quote">If I were you I would use a hasport mount kit for the drivers side. I did the exact same swap into my ek and I used the Si bracket with the stock mount and the stock mount broke. Use the Si bracket with a hasport kit. All the other mounts have held up so far. </TD></TR></TABLE>
does your car make a lot of noise with just one of the hapsport on? a friend of mine put in the driver side and the tranny side and its sound like he got an exhaust...
GrimeyAssLos
11
Feb 27, 2012 09:56 AM
SilverEk3dr
Dec 5, 2003 05:03 AM
turbospool
Sep 29, 2003 10:12 PM
black-hatch
Apr 21, 2003 09:08 AM
Ya@inlinePRO
Aug 27, 2002 11:37 AM
