I NeeD TO decide what swap i should THrow into my 92 teg
Old Mar 1, 2006 | 05:43 PM
OBDZEro's Avatar
Default I NeeD TO decide what swap i should THrow into my 92 teg
OK i have a 92 integra with a full jdm fornt clip but when i bought it it had a jdm ls with like b18 internals n its not running right so i have been tryign to decide between a b16b or b18c5... but i know that for christmas my car is going on boost aN so i dunno if i should just go all motor n drop k 24 i dunno i got money n need help
Old Mar 1, 2006 | 05:57 PM
fergy016's Avatar
Default Re: I NeeD TO decide what swap i should THrow into my 92 teg (OBDZEro)
well what do you want the car to do?
k20 top/k24 bottom custom build with turbo custom build that someone put into an rsx-s
What kind of power output do you want?
Have you thought about trying to get the power to the ground?
Do you have to worry about smog?
Old Mar 1, 2006 | 06:08 PM
OBDZEro's Avatar
i would like around 350 to 400 horses so im not sure what i should do but that setup sounds nice im sure it would cost tho big time
Old Mar 1, 2006 | 06:25 PM
fergy016's Avatar
I believe the owner is selling the engine set-up for $15k now minus the turbo set-up.
I am looking to do my gsr up to about that power range. The engine will be built by someone else, since I don't have the expertice.
head porting:
valves/seals/guide/retainers/
installation/removal parts
labor of radial valve job cost me $3k
Block build:
Sleeve
Low compression pistons
turbo kit
tuning
will be about $9k for 10-20psi capable engine.
Look through all the project cars on that site. There is a prelude they did with a gt40 turbo. It is 340hp at 10psi. I am building mine to play with him at the track.
I believe there is no replacement for displacement.
If your not comfortable building the engine yourself, I would find what the shop would want to do. They may be better at building NA set-ups or Turbo set-ups. You wont have the hp #'s the turbo set-up has but you will be faster since you wont have the turbo lag.
Superchargers aren't my friend. They get hot and make your intake air temperature rise more-so then a turbo would. This makes the engine produce less power.
Old Mar 2, 2006 | 03:54 AM
OBDZEro's Avatar
Default Re: I NeeD TO decide what swap i should THrow into my 92 teg (fergy016)
thats tru but i was in the forced induction forum n i was realizing that i shouldnt waste my money on a swap n just build my Ls well n then have it put on some crazy *** boost maybe t76 or soemthing .. tell me what u think
Old Mar 2, 2006 | 04:08 AM
Reid's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OBDZEro &raquo;</TD></TR><TR><TD CLASS="quote">it had a jdm ls with like b18 internals</TD></TR></TABLE>
There's no such thing as a JDM B18 non-VTEC.
Old Mar 2, 2006 | 06:56 AM
DC4love's Avatar
if ur gonna get a motor thats a REAl jdm motor get a b18c
Old Mar 2, 2006 | 08:38 AM
InLimbo87's Avatar
Default Re: I NeeD TO decide what swap i should THrow into my 92 teg (Reid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reid &raquo;</TD></TR><TR><TD CLASS="quote">
There's no such thing as a JDM B18 non-VTEC. </TD></TR></TABLE>
What? since when? last time i checked the integra ls in japan also came with the b18b (non-vtec). they had an xsi? i believe that had a sohc engine in it but there is definitely a non-vtec jdm engine (not that its any different than the usdm one)
Old Mar 2, 2006 | 09:14 AM
Rikter's Avatar
Swap your trans too? SIR from japan = Yum
-Rik
Old Mar 2, 2006 | 10:44 AM
cdizzle14's Avatar
B18 bottom end with ge sleeves,je low compression pistone eagle rods,acl bearings,then a gsr head with some springs,retainers,cams,valves,and then throw a huge turbo on that bitch.I know of a ten second 4 door out here and its a lsvtec turbo.
Old Mar 2, 2006 | 12:41 PM
. M i c h a e l's Avatar
dotmichael to you
Default Re: (Rikter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OBDZEro &raquo;</TD></TR><TR><TD CLASS="quote">thats tru but i was in the forced induction forum n i was realizing that i shouldnt waste my money on a swap n just build my Ls well n then have it put on some crazy *** boost maybe t76 or soemthing .. tell me what u think</TD></TR></TABLE>
first and foremost you need to figure out how much money you have now. and how much money you want to spend altogether..then add a good 5-600 dollars on top of that for things that will happen..because things will happen. and hey! if you're able to get it done with no mishaps..you have a few hundred left over for mods..or gas.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InLimbo87 &raquo;</TD></TR><TR><TD CLASS="quote">
What? since when? last time i checked the integra ls in japan also came with the b18b (non-vtec). they had an xsi? i believe that had a sohc engine in it but there is definitely a non-vtec jdm engine (not that its any different than the usdm one)</TD></TR></TABLE>
XSi is a 170 hp b16a. the only sohc engine teg in japan is that awd automatic version.
Old Mar 2, 2006 | 12:50 PM
markiebizzle's Avatar
I thought there was a JDM B18B....At least i remember my friend speaking of one. Maybe i'm mistaken though.
Old Mar 2, 2006 | 02:51 PM
standinghollow's Avatar
Default Re: (markiebizzle)
there is i bought one from hmotors last year as a replacement from throwing a rod.Its def jdm cause theres japenese printing on the side of it.Had it in for a year now.it does burn oil but i dont care it was only 900 shipped.And im ordering a full jdm b18c lsd swap from there too on monday.
Old Mar 2, 2006 | 02:55 PM
Micha's Avatar
FAILWGN
Default Re: (. M i c h e l l e)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by . M i c h e l l e &raquo;</TD></TR><TR><TD CLASS="quote">
XSi is a 170 hp b16a. the only sohc engine teg in japan is that awd automatic version.</TD></TR></TABLE>
For second gens yeah. But for third gens, you can get a DC1 with a zc motor I believe.
Old Mar 2, 2006 | 11:04 PM
fergy016's Avatar
I don't know which turbo is better per say. I am at a stand still on which way I want to go. I got a built head so now I gotta get the bottom end done to either high comp. or low comp to add some boost too.
I think building the ls is a wise decision. From a money stand point that is the best avenue to go.
Old Mar 3, 2006 | 04:54 AM
numbnuts22715's Avatar
go with a low compression.
With this you can have more boost and make more power.
just build it strong as **** man
Old Mar 3, 2006 | 06:44 AM
Reid's Avatar
Global Moderator
Default Re: I NeeD TO decide what swap i should THrow into my 92 teg (skylinedo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skylinedo &raquo;</TD></TR><TR><TD CLASS="quote">i think hmotors sells a http://www.hmotorsonline.com/s...earch </TD></TR></TABLE>
Weird, it's not listed in my Integra brochures as an engine choice.
Old Mar 3, 2006 | 06:52 AM
DC4love's Avatar
high compression all motor
chinchillad760
Jan 26, 2011 06:48 PM
chb93
11
Feb 3, 2009 11:15 PM
JeffRWRX
Apr 17, 2007 08:53 PM
XxDJCyberLoverxX
Nov 2, 2005 04:32 PM
