1991 accord RED Battery light stays on?
Old Feb 28, 2006 | 03:36 PM
tedog69er's Avatar
Default 1991 accord RED Battery light stays on?
On my 1991 accord the instrument panel battery light stays on. I check volts running it was 14.31 volts. ANy ideal ... THanks for your time.
Old Feb 28, 2006 | 03:45 PM
BLKFLSH's Avatar
Default Re: 1991 accord RED Battery light stays on? (tedog69er)
Does it crank good when starting? Do the lights go dim while cranking? Did you check the battery volts when it wasn't running? Should be a little over 12 volts. Could just be a bad, or corroded connection. Check your battery cables for white stuff (both ends).
Old Feb 28, 2006 | 03:53 PM
YeuEmMaiMai's Avatar
test your alternator. Most likely the voltage regulator has failed.
Old Feb 28, 2006 | 03:56 PM
P_Adams's Avatar
If it sometimes goes on, then turns off; you could have alternator armature brushes which have worn to the point they require replacing.
If it stays on constantly, check all your fuses, You cpuld have a feed-back problem.
It's also possible that you've got an internal Cluster problem (but let's leave this to last)
P
Old Mar 1, 2006 | 11:58 PM
knucklehead11's Avatar
last time my light came on my crank pulley broke and the tension on the belt loosened up and i got a weak charge when running. Dunno how but I was able to drive 15 miles on a broken crank pulley without overheating, without losing power steering, and without losing all electrical. I know, stupid move.
Old Mar 2, 2006 | 07:21 AM
P_Adams's Avatar
Default Re: (knucklehead11)
Like it or not, Honda took it upon themselves to drive the water pump with the Timing Belt, not the accessories drive belts (like on other cars).
It's nice that it kept you from overheating, but god help you should the water pump bearing fail and takes out the timing belt.
You'll have more thatn overheating to worry about.
P
Edited for Fat Fingered spelling error
Modified by P_Adams at 7:41 PM 3/2/2006
Old Mar 2, 2006 | 09:29 AM
Default Re: (P_Adams)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P_Adams &raquo;</TD></TR><TR><TD CLASS="quote">Like it or not, Honda took it upon themselves to drive the water pump with the Tining Belt, not the accessories drive belts (like on other cars).
P </TD></TR></TABLE>
lol it's all good
Old Jun 9, 2015 | 06:20 AM
parsapour's Avatar
Is there any practical test way to benchmark ALT bad regulator from the good one?
appreciate for incomming comments with thanks.
j4s0n1337
Feb 23, 2012 04:15 PM
eg6madness
Mar 4, 2007 07:37 PM
EG6[B16A1]
Feb 17, 2005 10:52 PM
311
Oct 23, 2002 05:19 AM
