B18b swap into 98 civc dx
Hey guys I just picked up the motor, tranny, and ecu today, i'm really excited. It is going into a 98 dx sedan. So far i've got the motor tranny ecu. What else do I need to get to get this swap going, in terms of which axles and stuff. Which mounts Do I use. I'm guessing I just get the LS shift linkage and throttle cable. Also can I use my wiring harness for this swap. I guess what I need is just a list of stuff that I need to get the motor in my car and running. Thanks for the info guys.
you are going to need b-series axles, shift linkage, and a 99 si rear bracket i believe, and a 99 si drivers side upper mount bracket, the one that bolts into the block, the rest of the mounts use the integra. and depending on what year the motor is, obd2 or obd1 will depend on whether the harness will work, and which ecu to get check this http://www.jspectuning.com/6gen/
[Modified by beeseries, 8:14 AM 3/29/2002]
noboostedEGo
Oct 20, 2005 12:39 PM
