shift linkage help!!!!!
Old Feb 23, 2006 | 03:54 PM
vtechrex's Avatar
Default shift linkage help!!!!!
i am doing a front end rebuild and i am replacing the cut and welded shift linkage with a brand new one. my problem is that the linkage is rusted solid to the selector lever that comes out of the tranny. i have tried pb blaster overnight and it is still not budging, i was wondering if anyone knew how to remove it
Old Feb 23, 2006 | 04:28 PM
vtechrex's Avatar
Default Re: shift linkage help!!!!! (vtechrex)
anyone know anything on this site, it seems like evertime i post something the only replies are people that want to light people up for the things they say but never give any advice.
Old Feb 23, 2006 | 05:39 PM
wood's Avatar
Could you possibly post a picture so we can see the problem? I know I couldn't post one, I don't know how.
Old Feb 23, 2006 | 06:06 PM
civickiller's Avatar
did you remove the bitch pin?
Old Feb 23, 2006 | 06:11 PM
e jay one's Avatar
Default Re: shift linkage help!!!!! (civickiller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civickiller &raquo;</TD></TR><TR><TD CLASS="quote">did you remove the bitch pin?</TD></TR></TABLE>
thats what i was gonna say. there would have to be a **** load of rust cause its not a tight fit.
Old Feb 26, 2006 | 07:53 AM
vtechrex's Avatar
Default Re: shift linkage help!!!!! (e jay one)
i removed the bolt that was in there cause the person before me didnt have the pin in there, and it still would not budge. i put vice grips on the rod comming out of the tranny, and pb blasted the connection point between the two, and i hit it with a hammer and a screw driver and still nothing, i have been driving for the last couple of days with no bolt or anything in there
Old Feb 26, 2006 | 11:50 AM
have you tried using a torch to heat it up?
Old Feb 27, 2006 | 03:39 PM
vtechrex's Avatar
no, you mean like a propane torch
Old Feb 27, 2006 | 10:52 PM
yup
Old Feb 28, 2006 | 12:00 AM
Ak_ef9's Avatar
Read this. There shouldnt be a bolt
https://honda-tech.com/zerothread?id=634850
Old Feb 28, 2006 | 12:02 AM
STREETWERKZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtechrex &raquo;</TD></TR><TR><TD CLASS="quote">anyone know anything on this site, it seems like evertime i post something the only replies are people that want to light people up for the things they say but never give any advice.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtechrex &raquo;</TD></TR><TR><TD CLASS="quote">have been driving for the last couple of days with no bolt or anything in there</TD></TR></TABLE>
maybe thats why?
Old Feb 28, 2006 | 12:18 AM
EFM_ookie's Avatar
Default Re: shift linkage help!!!!! (STREETWERKZ)
if ur going to replace it just take a dremel to it and cut it off... thats what i did when i bought my tranny with the fed up linkage
Old Feb 28, 2006 | 07:49 AM
J4k3's Avatar
Default Re: shift linkage help!!!!! (89_Mangina_SI)
I'm also trying to get mine out now and its a big pain in the ***. I've tried beating on it, grinding it flush to get rid of any rolling, and nowdrilling. I broke off a small punch inside of the pin and it seems to have made the pin wider and harder to get out. Today after school im going back to drilling the bitch out and replace it with a nut and bolt.
Old Feb 28, 2006 | 10:25 AM
Default Re: shift linkage help!!!!! (J4k3)
there is no perfect size botl of that, there will be alot of play in your shifter. you have to use a flat punch, you can use one with a pointed tip because a pointed tip will make it expand further only locking it in there more. flat punch is the way to go, i know i bought a flat punch at sears and it fit it perfect. sorry idk the size of it
Old Feb 28, 2006 | 11:25 AM
sloweredcivic's Avatar
when i did mine i just picked the next size up of drill bit and bored it out the drilled the new linkage to match then found a bolt to fit that hole
Old Feb 28, 2006 | 06:19 PM
J4k3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civickiller &raquo;</TD></TR><TR><TD CLASS="quote">there is no perfect size botl of that, there will be alot of play in your shifter. you have to use a flat punch, you can use one with a pointed tip because a pointed tip will make it expand further only locking it in there more. flat punch is the way to go, i know i bought a flat punch at sears and it fit it perfect. sorry idk the size of it</TD></TR></TABLE>
i was told its a 1/4'' punch
Old Mar 2, 2006 | 07:55 AM
vtechrex's Avatar
i got the bolt out already. the two seperate parts are just so shitty that they are rusted together and they wont seperate
MikeY326
Dec 27, 2009 10:35 PM
sosleepy
Mar 16, 2006 06:25 AM
stegon78
Jun 24, 2005 08:46 AM
crxhf19
Jan 28, 2005 08:16 PM
MR. MIYAGI
Mar 12, 2004 12:34 PM
