VIBRATION?!?!
Old Feb 23, 2006 | 11:43 AM
gr33kwrx's Avatar
Default VIBRATION?!?!
I just bought another eg to sart working on but theres a problem....i've replaced both front wheel bearings, inner and outer tie rods, the rf axle, pads and rotors in the front, wheels are balanced but i still have something making the car wobble at all speeds from about 20 and above and worse at times....theres a slight sound and you can even feel alot of vibration in the driverside of the front end while driving so is it possible that the drive axle is the culprit eventhough the axle doesnt look bad, could it need to be replaced? if not can anyone please help??
Old Feb 23, 2006 | 12:03 PM
gr33kwrx's Avatar
anyone?? any ideas at all?
Old Feb 23, 2006 | 12:05 PM
Luserkid's Avatar
Default Re: VIBRATION?!?! (gr33kwrx)
The axle could be the problem but at the same time, hows your mounts?
Old Feb 23, 2006 | 12:06 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: VIBRATION?!?! (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">The axle could be the problem but at the same time, hows your mounts? </TD></TR></TABLE>
dose the vibration go away when you let off of the gas? if so it is in the inner cv joint.
Old Feb 23, 2006 | 12:24 PM
gr33kwrx's Avatar
this vibration is anytime the car is moving whether im on the gas or not, its something thats rolling in the front driverside, like i said you can hear/feel it in the pedals/floor, mounts are all decent, symptoms say wheel out of balance if that gives you an idea of what its like, only my wheels are balanced
Old Feb 23, 2006 | 12:25 PM
nabd98r's Avatar
shitty
Freemananana
44
Jul 23, 2014 02:57 AM
that1s10
Nov 16, 2008 08:06 AM
DarkBB4
Apr 22, 2007 09:29 PM
SilverDc2
Jun 25, 2003 04:02 PM
StockTeg
Aug 1, 2002 09:15 AM
