Wierd Idling Thing
Old Mar 28, 2002 | 03:01 PM
1HotHonda's Avatar
Default Wierd Idling Thing
Today I noticed that whenever I stop for a stop sign or a light, my car (98 Civic EX) idles really low (around the 400rpm range)... It shakes a little, like it's going to stall, but when I go again, I've got plenty of power, and no problems... Any ideas?
Old Mar 28, 2002 | 03:04 PM
DragII's Avatar
25 Year Member
Default Re: Wierd Idling Thing (1HotHonda)
check for vac leaks, change fuel filter, clean/change air filter.
Old Mar 28, 2002 | 03:26 PM
speedillusion's Avatar
New User
might be as simple as adjusting the throttle cables. just my .02 cents
Old Mar 29, 2002 | 08:43 PM
Mista Bone's Avatar
D Tranny Guru
Try cleaning the TB, works everytime.
Old Mar 29, 2002 | 09:20 PM
ToneyTigre's Avatar
New User
Default Re: Wierd Idling Thing (Mista Bone)
whats the TB? and can you explain why the cable throttle has anything to do with idle? i have the same problem too. thanks.
[Modified by ToneyTigre, 10:22 PM 3/29/2002]
Old Mar 29, 2002 | 09:36 PM
d8168055's Avatar
Default Re: Wierd Idling Thing (ToneyTigre)
TB= throttle body... the throttle cable adjusts a butterfly "leaf" that allows air to pass into the engine... when u adjust the cable, u may let more air in at idle and not get that low idle... acutally, i have the same prob too, any other suggestions?
Old Mar 29, 2002 | 09:56 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: Wierd Idling Thing (d8168055)
throttle cable should have about 1/4-3/8" deflection in it when adjusted properly. If it is NOT over tighten then it CANNOT effect the idle in ANY way.
Cleaning the TB removes the gunk that gets built up around the butterfly. VERY common on Accords. Honda even has a TSB addressing this issue.
Old Mar 30, 2002 | 07:35 AM
97hb's Avatar
Might be your iac sensor. If my car is warmed up and I pull the sensor off its clip idles around 480 rpm(if the car is cold it will just die). Don't know if it would throw a code or not if the sensor is messed up. Mine threw a code when I unplugged it.
bk7794
13
Jun 21, 2012 08:17 PM
cdmef
Jul 3, 2011 06:03 AM
hybridEj6
Oct 5, 2006 11:23 AM
user 98292739
Dec 29, 2004 02:01 PM
MetalKill
15
May 26, 2002 09:53 PM
