MSD or OEM?
Old Feb 22, 2006 | 09:17 PM
Nataku's Avatar
Default MSD or OEM?
Ok so It has been brought to my attention that my ignitor is going bad.
So i'm getting ready to replace it, was going to order one from len for $166 when I found this http://www.prostreetonline.com...mance/
what should I do? or is there more I need then just that MSD ignition?
Old Feb 23, 2006 | 02:52 AM
KayOs's Avatar
Default Re: MSD or OEM? (Nataku)
Stick with OEM...you will have less headaches.
Old Feb 23, 2006 | 04:37 AM
cltitus's Avatar
OEM is great but depending on ifyour doinug future engine modsi would replace the whole ignition system somewhat likei did little costly at firstbut im glad i got it out the way. If your keeping this just like a daily driven econ car just buy a replacement oem andsleep better at night.
good luck
Old Feb 23, 2006 | 04:56 AM
Opie's Avatar
MSD = the suck. Don't get me started on that ****. I'll go on for hours.
Old Feb 23, 2006 | 05:24 AM
Dave-ROR's Avatar
Default Re: MSD or OEM? (cltitus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cltitus &raquo;</TD></TR><TR><TD CLASS="quote">OEM is great but depending on ifyour doinug future engine modsi would replace the whole ignition system somewhat likei did little costly at firstbut im glad i got it out the way. If your keeping this just like a daily driven econ car just buy a replacement oem andsleep better at night.
good luck</TD></TR></TABLE>
There are very very very few cases where the OEM ignition system is not perfectly capable.
And I would venture to guess that the OP is not one of those cases.
Use the OEM gear.
Old Feb 23, 2006 | 12:37 PM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Default Re: MSD or OEM? (billybaggiosBACK)
Use the OEM stuff. When I got my car it had MSD, cant say anything bad about it but I took it off.
Old Feb 23, 2006 | 03:12 PM
KayOs's Avatar
Default Re: MSD or OEM? (walker111)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 &raquo;</TD></TR><TR><TD CLASS="quote">Use the OEM stuff. When I got my car it had MSD, cant say anything bad about it but I took it off.</TD></TR></TABLE>
it's overkill for a street setup.
Old Feb 23, 2006 | 08:16 PM
Nataku's Avatar
Default Re: MSD or OEM? (KayOs)
what about this autozone ignitor i'm hearing about? stay away?
from the expierence I've had with Autozone (or any other around the corner store) there stuff is kind of cheaply made. I've had a few of their caps and rotors fail and a lot of the screws with their caps snap off on me.
any thoughts?
Old Feb 23, 2006 | 10:01 PM
Mike K's Avatar
bottom line is.. your igniter took a ****, right? so how is an ignition box going to solve that issue? that just amplifies the signal that the igniter gets.
you need an igniter, regardless. get oem. does it say NEC or hitachi on your igniter? i noticed integra ones cost more. try and look at some accord or civic ones. you'll find one that fits.
Old Feb 24, 2006 | 07:06 AM
b19coupe's Avatar
Just stay away from the OKI igniters, or any cheap Autozone igniter.
Old Feb 24, 2006 | 07:11 AM
cool guy name
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KayOs &raquo;</TD></TR><TR><TD CLASS="quote">
it's overkill for a street setup.</TD></TR></TABLE>
I agree, thats why its off. But it didnt have a negative effect on anything while it was on my car.
Old Feb 24, 2006 | 12:19 PM
type_r_jon's Avatar
i've had msd for about 40 k , no problems. you will hear a lot of bad **** about it but I personally have experienced no problems. I have msd cap and coil and 8.5 wires. I noticed a slight improvement in throttle response. I would agree that if you have not heavily modified your car it will probably be best to keep it the way the Honda gods intended and spend the money some place else.
Old Feb 24, 2006 | 02:40 PM
ITR-00-1457's Avatar
Default Re: MSD or OEM? (type_r_jon)
I have had no problems with my MSD cap, coil, or wires but my Digital6 sucked!
Old Feb 24, 2006 | 02:59 PM
Spunkster's Avatar
Why not buy the Distributor King/RPM Partz distributors, they come with all new parts and are only about $200.
Genesis777
Jun 18, 2017 06:40 PM
EJ8Squad919
Jun 16, 2012 11:41 AM
smores
Sep 19, 2006 08:47 PM
EE_Chris
Apr 28, 2005 12:16 PM
mr.beeks
Jul 30, 2003 07:14 AM
