what kind of oil do i use???
Old Feb 22, 2006 | 08:59 PM
Terrible One's Avatar
Default what kind of oil do i use???
sorry for the noob question, i got a stock jdm h22a in my hatch, just wondering what oil and how much. im in utah, elevation 4200ft and it snows.
Old Feb 22, 2006 | 10:37 PM
bad-monkey's Avatar
5w30.
Old Feb 22, 2006 | 11:37 PM
hu's Avatar
hu
How many miles on the H22?
Old Feb 23, 2006 | 04:37 AM
The Weather Man's Avatar
Default Re: (bad-monkey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bad-monkey &raquo;</TD></TR><TR><TD CLASS="quote">5w30.</TD></TR></TABLE>
I second that.
Old Feb 23, 2006 | 04:59 AM
Drag'nGT's Avatar
Some guy I was chatting with said that he put 10w30 in his. I couldn't figure out why, nor do I know the reasons not to. Otherwise I would have told him not to. Can anyone educate me on this?
Old Feb 23, 2006 | 05:06 AM
Default Re: (Drag'nGT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Drag’nGT &raquo;</TD></TR><TR><TD CLASS="quote">Some guy I was chatting with said that he put 10w30 in his. I couldn't figure out why, nor do I know the reasons not to. Otherwise I would have told him not to. Can anyone educate me on this?</TD></TR></TABLE>
Its just the viscosity. 10w30 won't hurt at all.
Old Feb 23, 2006 | 06:26 AM
Lewdin' Incognito's Avatar
Default Re: (TheKINGPin)
Honda calls out 10W30 for the H23 and 5W30 for the H22.
I'd say it's your call, doesn't really matter 99.9% of the time.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by http://www.nordicgroup.us/oil....10W30 &raquo;</TD></TR><TR><TD CLASS="quote">5W30 versus 10W30
Virtually all new passenger vehicles sold in the U.S. use either 5W30 or 10W30 oil. The difference between the two is that the 5W30 flows better when cold, so if you live in a cold climate or operate your vehicle in a cold climate during the winter months, you should use 5W30 if it is the preferred oil for your vehicle. If you live in a sub-tropical climate and don't operate your vehicle in cold climates, then 10W30 is acceptable as long as the manufacturer specifies that it is permissible to use it.</TD></TR></TABLE>
Old Feb 23, 2006 | 06:45 AM
OH ****!!!! I'm so slow...........i just read your sig - thats nice.......... Ha. I'm laughin my *** off right now.
Old Feb 23, 2006 | 06:57 AM
connvict's Avatar
What about a higher viscocity, higher thickness oil for road racing or racing alone applications? (i.e. 10/40-20/50)
Anyone tried this with good or bad results?
Old Feb 23, 2006 | 07:18 AM
maks's Avatar
Default Re: (connvict)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by connvict &raquo;</TD></TR><TR><TD CLASS="quote">What about a higher viscocity, higher thickness oil for road racing or racing alone applications? (i.e. 10/40-20/50)</TD></TR></TABLE>
If you're racing in very hot temperatures for extended periods of time, and don't have better cooling to compensate for these conditions, then yes, xW40's and xW50's will help prevent shearing of the oil.
However, Honda (and all manufacturer's afaik) test their engines in extreme conditions both hot and cold, for very long periods of time, and if 5W30 or 10W30 has been approved by their engineers, I figure it's good enough for my once-in-a-blue-moon track day, even if it's warm.
Maks
Old Feb 23, 2006 | 10:48 AM
Buzzbomb's Avatar
Default Re: what kind of oil do i use??? (Terrible One)
Read, educate yourself and make your own decision.
https://honda-tech.com/zerothread?id=1534856
Old Feb 23, 2006 | 12:07 PM
maks's Avatar
Default Re: what kind of oil do i use??? (Buzzbomb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Buzzbomb &raquo;</TD></TR><TR><TD CLASS="quote">Read, educate yourself and make your own decision.</TD></TR></TABLE>
For sure, the Motor Oil Bible is actually quite an interesting read (for those interested in the mechanics of your car)
Old Feb 23, 2006 | 07:03 PM
hondaprelude93p13h22a's Avatar
If you have alot of miles on your engine or your rings are bad i find if you use a heavier weight oil, you get better compression and it wont burn alot of oil while driving.
I use 20W50 in my 93 lude h22 and haven't had any problems....
Old Feb 23, 2006 | 07:17 PM
6E LUDE's Avatar
Default Re: (hondaprelude93p13h22a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaprelude93p13h22a &raquo;</TD></TR><TR><TD CLASS="quote">If you have alot of miles on your engine or your rings are bad i find if you use a heavier weight oil, you get better compression and it wont burn alot of oil while driving.
I use 20W50 in my 93 lude h22 and haven't had any problems....</TD></TR></TABLE>Same here. I have a Turbo'd H22 and use Valvoline Racing 20w50 oil and no complaints. I might go to 10w30 on the next oil change and see if I can notice a difference in mileage and performance.
Old Feb 23, 2006 | 08:06 PM
EOE's Avatar
EOE
Default Re: (6E LUDE)
H22A1 4th gen manual: the oil that is required to use 10w30 UNLESS the temperatures are VERY low, then it gives you the chart.
H22A4 5th Gen manual: 5w30
Not that it really matters. But that is what HONDA recommends.
Old Feb 24, 2006 | 05:25 AM
Slatelude's Avatar
Default Re: (EOE)
I bought my car w/ 122K on it H23, and the owner had always used 5w30 Quaker State (i know, i know), I stuck with the QS, but since I was commuting more at the time and the mileage was getting up there I switched to the 10w30, longer break down time. Car just rolled 200k and have only had to replace the normal seals and she still gets 28mpg on an average tank.
K
Old Feb 24, 2006 | 06:09 AM
The_Sober's Avatar
Default Re: (Slatelude)
my girlfriend's Mazda uses 5W20...I've run 0W60 in some of my track bikes...
https://honda-tech.com/zerothread?id=1534856</TD></TR></TABLE>
excellent link
B16b-EJ8
13
Apr 24, 2007 03:57 PM
LukieLuc
Apr 5, 2007 07:39 AM
Kwayzie
16
Mar 20, 2007 04:28 PM
jowy
Mar 3, 2005 11:09 PM
quazar
11
Oct 23, 2004 05:50 AM
