A/c belt install
Old Feb 22, 2006 | 06:20 AM
Shaun's Avatar
Default A/c belt install
my a/c is all there... all is needed is the belt I have the belt .... do I have to take the compressor off to put on the belt or do I have to take the mount off also, and do I have to losen the tensior before I put the belt on?
Old Feb 22, 2006 | 06:35 AM
1bad-eg's Avatar
Default Re: A/c belt install (Shaun)
If it's a 94-01 you need to remove the 2 bolts that hold the a/c bracket mount out, and what I also do is loosen the 2 nuts and 1 bolt from the driver's side upper mount.....don's take them out just loosen them and that should give you enough clearance to pull the a/c belt out from under the car.
Old Feb 22, 2006 | 06:39 AM
Shaun's Avatar
im installing the a/c belt.. thanks ill try that method! ^^ should i losen the tensior first?
Old Feb 22, 2006 | 07:28 AM
1bad-eg's Avatar
Default Re: (Shaun)
Yep.
Old Feb 22, 2006 | 07:31 AM
Shaun's Avatar
****... i guess the power steering belt has to be taken off also to get the belt on?
Old Feb 22, 2006 | 07:53 AM
1bad-eg's Avatar
Default Re: (Shaun)
Yes, you have to move the ps pump out of the way so you can relieve the belt tension.
Old Feb 22, 2006 | 08:55 AM
Shaun's Avatar
FINISHED !! thanks!! .. my damn knuckles hurt from using hand tools haha.. a/c BLOWS COLD
Old Feb 22, 2006 | 10:24 AM
1bad-eg's Avatar
Default Re: (Shaun)
Cool man.
ShinyNewPenny
Aug 8, 2008 06:45 PM
Civic Owner
Sep 24, 2007 06:02 PM
bazian1114
May 4, 2005 05:36 PM
NoLipRacen
Oct 31, 2003 07:57 AM
J T*
14
Apr 5, 2002 06:21 PM
