o2 sensor
is it necessary to install an o2 sensor especially if there isnt an emissions law where im at? i mean does the engine really work any better or worse without it? and my car has hondata, do i have to change the ecu for a d16z6. (previous owner had the car turbo'd with a non vtec 1.6 head)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swindler86 »</TD></TR><TR><TD CLASS="quote">is it necessary to install an o2 sensor especially if there isnt an emissions law where im at? i mean does the engine really work any better or worse without it? and my car has hondata, do i have to change the ecu for a d16z6. (previous owner had the car turbo'd with a non vtec 1.6 head)</TD></TR></TABLE>
yes... the o2 i believe signals air/fuel ratio. as in how much more air or fuel should be added to the mixture.
unless you want your car to run really rich and get terrible gas milage, i recommend running with a 02 sensor. And your hondata program would be Completely different for a D16z6 as apposed to a non-vtec turbo D. my guess is you prolly shouldn't try to figure out any type of wiring on your own.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swindler86 »</TD></TR><TR><TD CLASS="quote">anyone know where i can get a write up of how to change it to a four wire o2</TD></TR></TABLE>
its the same 4 wire or single wire just run a o2
i was running without the primary o2 sensor for a week and my car ran fine. right now m y secondary o2 sensor is bad and i still have the same gas mileage. according to my car the o2 sensors dont do ****
