eg jdm gauge cluster
Old Feb 21, 2006 | 06:51 PM
frosty4door's Avatar
Default eg jdm gauge cluster
just wondering if anyone else has one. i got mine and everything works except the dimmer. is there any way to correct this?
Old Feb 21, 2006 | 07:22 PM
likwid_sunshine's Avatar
Default Re: eg jdm gauge cluster (frosty4door)
Dimmer control does not work on the JDM Cluster... just replace the bulbs in the back of the cluster... and you will notice a huge difference
Old Feb 21, 2006 | 07:56 PM
BlueIntegraBoy's Avatar
Swap over the gauges to a USDM cluster housing to retain dimmer control.
Old Feb 21, 2006 | 08:43 PM
GetawayInMoscow's Avatar
Default Re: eg jdm gauge cluster (likwid_sunshine)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by likwid_sunshine &raquo;</TD></TR><TR><TD CLASS="quote">Dimmer control does not work on the JDM Cluster... just replace the bulbs in the back of the cluster... and you will notice a huge difference </TD></TR></TABLE>
Replace them with what? Have a pic of yours? Mine is dim as hell, kinda weak....
Old Feb 21, 2006 | 09:40 PM
crayziewillie's Avatar
Default Re: eg jdm gauge cluster (GetawayInMoscow)
I used the 3 fat bulbs with the blue condoms from my original cluster. I took off the blue condoms, and had a buddy who gave me another 3 fat bulbs. I replaced all of the grey ones on the JDM one.
Btw, you can tell if your jdm bulbs are burned out if the holder thingy has a browned burned look around the bulb area.
Old Feb 22, 2006 | 08:07 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GetawayInMoscow &raquo;</TD></TR><TR><TD CLASS="quote">
Replace them with what? Have a pic of yours? Mine is dim as hell, kinda weak....</TD></TR></TABLE>
Replace them with new bulbs!! What do you think! Just head over to your local parts shop, pull the bulbs from the back of your cluster (should have brown backings) and tell them you want new bulbs. I believe the size is 24... could be wrong...
Old Feb 22, 2006 | 04:22 PM
Replace them with new bulbs!! What do you think! Just head over to your local parts shop, pull the bulbs from the back of your cluster (should have brown backings) and tell them you want new bulbs. I believe the size is 24... could be wrong...</TD></TR></TABLE>
Yeah but I thought the JDM clusters use amber bulbs that you can't get in the US. Either they don't have the same size or the same color. That's why I was asking.
Thanks for your smart *** remark though
Old Feb 22, 2006 | 04:28 PM
riceburnerryan's Avatar
i think the bulbs are amber because of the bulb condoms
Old Feb 22, 2006 | 04:42 PM
Default Re: (riceburnerryan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceburnerryan &raquo;</TD></TR><TR><TD CLASS="quote">i think the bulbs are amber because of the bulb condoms</TD></TR></TABLE>
Bulbs are not amber, the inside of the gauge face is.
Old Feb 22, 2006 | 07:29 PM
JDMEK206's Avatar
Default Re: (BlueIntegraBoy)
just get new bulbs or transfer the ones from the usdm. U don't need to switch the housings tho.
K20egcw
18
Feb 23, 2012 11:21 AM
B16aCRXSi
17
Jan 19, 2009 08:13 PM
roycivic92
Jul 14, 2008 04:45 AM
D15Bbigred
Nov 20, 2006 07:28 AM
BuBBa y0!
Jun 13, 2005 02:46 AM
