Engine Builders - need some advice
Old Feb 21, 2006 | 06:43 PM
rizen's Avatar
Default Engine Builders - need some advice
I'm getting ready to put the car down and build the motor. I've pretty much decided on what I'm doing, but I've come to a small road block in the decision making process and need some advice from some of the experts...
I've decided to go with an 84mm bore. Choice of sleeve is Darton. However, the engine builder recommended that I use the flanged sleeve instead of the mid kit. Problem with that is, they only go as high as 83mm. The builder mentioned that the flanged sleeve is a more streetable application and said why. I just don't remember all of his reasons.
Has anyone here run the mid kit? Any known issues? I've searched, but didn't find much.
Thanks in advance
Old Feb 21, 2006 | 06:49 PM
Haleiwa-Brando's Avatar
Default Re: Engine Builders - need some advice (rizen)
Is this 'flanged sleeve' proprietary to the person your talking to?
Being limited to 83mm in an all motor build-up kind of seems like a moot point don't you think?
Old Feb 21, 2006 | 06:58 PM
rizen's Avatar
Default Re: Engine Builders - need some advice (Haleiwa-Brando)
No, it's not.
I should of mentioned, it will be a boosted application.
Old Feb 21, 2006 | 06:59 PM
itralex's Avatar
imo, if you're set on using darton sleeves. Get Earl/Benson to sleeve your motor
Old Feb 21, 2006 | 07:02 PM
JjuuN R's Avatar
Default Re: Engine Builders - need some advice (itralex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itralex &raquo;</TD></TR><TR><TD CLASS="quote">imo, if you're set on using darton sleeves. Get Earl/Benson to sleeve your motor</TD></TR></TABLE>
good idea, but not when he's ALL THE WAY across the country
Old Feb 21, 2006 | 07:05 PM
rizen's Avatar
I'm really not looking to ship out the motor. The builders I'd be using locally preps Titan Motorsports blocks and has a real good rep.
Old Feb 21, 2006 | 07:06 PM
JjuuN R's Avatar
perfect...
Old Feb 22, 2006 | 10:21 AM
rizen's Avatar
Anyone else?
Old Feb 22, 2006 | 11:56 AM
Mr. Roboto's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rizen &raquo;</TD></TR><TR><TD CLASS="quote">Has anyone here run the mid kit? Any known issues? I've searched, but didn't find much.
Thanks in advance
Nope I got the m.i.d. kit and my bottom end is fully built. I'm boosted an I give it a good beating, no problems. Good luck with yours
Old Feb 22, 2006 | 12:23 PM
rizen's Avatar
Default Re: Engine Builders - need some advice (Mr. Roboto)
Daily driven? How much power are you putting down on 93?
Thank you for the response
Chance EG
29
May 9, 2017 05:22 PM
h22a193
Jun 20, 2004 03:47 PM
Train
Mar 20, 2004 07:46 PM
vtec.dc2
Sep 18, 2003 03:16 PM
boostdGS
Mar 25, 2003 12:26 PM
