ball joint
Old Mar 28, 2002 | 08:21 AM
fiebru1119's Avatar
Default ball joint
what does this do? is it an essentail suspension component?
i ask because i think i broke mine last night. i was swapping axles and when using the puller to release the joint from the LCA, the rubber cushion ruptured w/all the grease coming out. am i in any immediate trouble?
Old Mar 28, 2002 | 08:35 AM
92sleepR's Avatar
New User
Default Re: ball joint (fiebru1119)
This should probably be in Newbie questions but i'm feeling generous today.
First, Yes, the ball joints are an essential part of the suspension and Yes, if you tear the rubber dust boot and don't fix it you are going to ruin the joint.
Fortunately it's an easy repair. Get a new dust boot from a Honda dealer or http://www.hondaautomotiveparts.com Carefully remove the retainer clip that holds the boot to the groove in the ball joint. replace the dust boot and re-install the retainer. Honda has a special conical tool that makes slipping the ring on really easy but the tool is also really expensive. You can do it without it but be carefull not to cut or pierce the boot.
Mike
Old Mar 28, 2002 | 09:17 AM
fiebru1119's Avatar
Default Re: ball joint (92sleepR)
sorry bout the newbie thing.. didnt really think about that. but thanks alot for the help, i'm gettin on that tomorow night
beanbag
Transmission & Drivetrain
Apr 28, 2014 08:34 PM
hi ho silver
Nov 3, 2010 05:11 AM
SanJose408
Feb 21, 2009 08:38 AM
BigZ88
May 21, 2003 02:43 PM
customx_
Jan 18, 2002 06:33 AM
