REMOTE WIRE
You're talking about the blue wire coming off the deck? That wire would be extended and run to your amp remote turn on input if you had amps. If you don't, then insulate the tip.
Ground the amp to the bare metal chassis near the amp. I prefer factory bolts, and I take the paint off with a special bit I have.
If your looking for the factory remote wire, its probably an accesory wire. But to save time and hassle, get yourself a plug n play factory wire harness plug. Any local stereo shop sells them and saves you from hacking away at your factory harness and usually makes the install pretty clean
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid-Performance.com »</TD></TR><TR><TD CLASS="quote"> But to save time and hassle, get yourself a plug n play factory wire harness plug.</TD></TR></TABLE>
I think in this case using a harness and reverse harness would be a lot of work when all you need to tap is one wire for the remote. Also then you have to try to fit an additional 2 plugs all the wires and connectors as well as a line out converter behind the radio. I would probably just tap the wires.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MLD211 »</TD></TR><TR><TD CLASS="quote">
I think in this case using a harness and reverse harness would be a lot of work when all you need to tap is one wire for the remote. Also then you have to try to fit an additional 2 plugs all the wires and connectors as well as a line out converter behind the radio. I would probably just tap the wires.</TD></TR></TABLE>? you would only need the oem radio harness plug adapter, [into car adapter] Metra 20-1721, connect it color for color with the Alpine harness, then use the blue/white, as FULL throTTLe mentioned, the solid blue on an Alpine HU is power ant. control and has no power when CD is playing.
94
94
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm »</TD></TR><TR><TD CLASS="quote">? you would only need the oem radio harness plug adapter, [into car adapter] Metra 20-1721, connect it color for color with the Alpine harness, then use the blue/white, as FULL throTTLe mentioned, the solid blue on an Alpine HU is power ant. control and has no power when CD is playing.
94</TD></TR></TABLE>
I was responding to this, meaning if he was running a factory radio. With the after market there would be no need for the factory turn on. obviously. I think I just mis read the post.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid-Performance.com »</TD></TR><TR><TD CLASS="quote">If your looking for the factory remote wire</TD></TR></TABLE>
94</TD></TR></TABLE>I was responding to this, meaning if he was running a factory radio. With the after market there would be no need for the factory turn on. obviously. I think I just mis read the post.
boostincoupe
Audio / Security / Video
Oct 6, 2005 05:19 PM
another_crx
Dec 28, 2003 06:39 AM
