oxygen sensor stuck old header old header not fit in car
Old Feb 18, 2006 | 02:21 PM
96accordlxf22b2's Avatar
I cursed out BauleyCivic and got banned
Default oxygen sensor stuck old header old header not fit in car
old header dont work anymore o2 sensor is stuck cant buy the tool cuh no running car suggestions list em
tried so far 7/8 open end wd 40
tred cresent wrench managed to round the ****** off
nearest autozone 20 miles nearest honda dealarship for new sensoer 40 miles no autoparts stores around no running car to drive 17 years old working on daily driver motorcycle doesnt run
Old Feb 18, 2006 | 02:25 PM
Default Re: oxygen sensor stuck old header old header not fit in car (96accordlxf22b2)
bump have about 30 mins to fix tis bullshit
Civicse's Avatar
man i'm assuming english is your 10th language. use a 22mm wrench on the o2 senor. and fix your motorcylce
3 mintues now that i took the time to type it
type fast no vocablaury or personality so flame and ill walk to ur house and kill u
Old Feb 18, 2006 | 02:26 PM
Civicse's Avatar
Default Re: oxygen sensor stuck old header old header not fit in car (Civicse)
you need to heat it up also
no tengo un 22 mm wrench
rounded o2 sensor
heat with????? all i got is about a 30 ent lighter i dont have anything to heat it up unless its an oven lol
Old Feb 18, 2006 | 02:27 PM
thnx for help anyways i really need this done
Civicse's Avatar
ok walk to my house. my pet minitar will eat you
Old Feb 18, 2006 | 02:28 PM
Civicse's Avatar
turn the car on for 5 mins, that wil heat it up
good idea
Old Feb 18, 2006 | 02:29 PM
Civicse's Avatar
use some channel locks or a vise grip if its rounded
thnx ill go try that brb in about 10 minutes
Old Feb 18, 2006 | 02:31 PM
heating it up now im going to try the vice grips
whts a channel lock?
Old Feb 18, 2006 | 02:32 PM
nvm googled channel locks same thing as a slip-joint pliar right?
Old Feb 18, 2006 | 02:33 PM
Civicse's Avatar
yep. or a device to lock channels on your tv, but the might no work
Old Feb 18, 2006 | 02:39 PM
ty man
Old Feb 18, 2006 | 02:41 PM
Civicse's Avatar
come out ok?
Old Feb 18, 2006 | 05:15 PM
no im going to put on another one no axygen sensor is there a way i can tell the ecu there is a oxygen sensor with an ok signal?
Old Feb 18, 2006 | 05:22 PM
teamvirus's Avatar
My car breaks a lot!
that sucks
MainStreamHonda
Aug 9, 2011 09:36 AM
pli
41
Feb 27, 2007 05:49 AM
egcivic
18
Mar 21, 2005 10:56 PM
f1uxx
May 8, 2003 09:45 PM
integraautox
Sep 23, 2002 01:18 AM
