WHATS THIS?? HELP!!
i was driving my car and it started makin some crazy noise, poppd my hood and noticed this. is this the motor mount? how much would it cost for a new one? where can i get one at.?? HELP
Modified by ph0shizzle at 6:54 PM 2/18/2006
http://www.sportcompactwarehouse.com/PROD/EKSTK
this is the link im assuming it is a d series, but the mounts are for b and d series, but they will set you back about $445.00
so i just need to buy a new motor mount and itll be coo? but isnt a motor mount only the top piece? damn.. i didnt expect itd cost that much for a new drivers side motor mount..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silverwannabeEM1 »</TD></TR><TR><TD CLASS="quote">http://www.sportcompactwarehouse.com/PROD/EKSTK
this is the link im assuming it is a d series, but the mounts are for b and d series, but they will set you back about $445.00</TD></TR></TABLE>
He doesn't need the entire kit, FYI some companies sell just the driver side mount.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ph0shizzle »</TD></TR><TR><TD CLASS="quote">where can i buy this at??? junkyard? is it worth buyin another stockd one? how much do you think it will cost?</TD></TR></TABLE>
Is your car stock? If it is just buy another stock mount and call it a day. If it's built at all (trubo or n/a) buy the single hasport mount.
You could find one at a junkyard but chances are that one is going to be bad or about to blow.
Get a new one from honda or some place that sells them new. Autozone or pep boys probably has them. Cost will probably be about 150-200 maybe less. If you have it installed, about 400.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TTM »</TD></TR><TR><TD CLASS="quote">ha **** what were you doin? hill jumping?</TD></TR></TABLE>
I'm wondering the same thing. Also, what the hell the engine is sitting on to stay in that position. I'm ALSO betting that his lower A/C mount is bad now with how extreme that engine is sitting.
DAMN you got a hold of that one!!
I did the same thing only mine tore itself right out of the block and shredded the power stearing belt
I tried to fix it myself but ended up having to pay $400 to have the block heli-coiled the retap the block and thn remove the block bolt. It looks like yours just snapped the bolt that goes up the center of the mount. Maybe that bolt might be separate from the mount itself in which case u could buy a new bolt? Your best bet is to check that first, then if not, buy the hasports.
yea , but i dont got power steering or AC. the motor is slanted and it started makin wierd noises whenever i took off but it BROKE right in front of my house so i dont think anythings too fuccd up cuz i didnt drive it like that anywhere cept maybe 10 ft
ah i broke that mount many times =X hehe!
its okay though!!! haha that mount is a POS... stupid liquid filled mount. makes for smoother ride i guess.
try look around, i beleive the integra mount is solid, not liquid filled like that thing... i started brekaing mounts when i switched to a b series.
but yes your lower AC mount must be off or broken LOL!!!!
but uhm from honda, you can order that driverside mount for about 60 bux... for a OEM one. its pretty easy to replace, just jack up the motor and take the mount out and replace wahlah
nice pics though =D
nice pics though =D
if the AC mount is broken or off , does it make a diff ? or do i have to get that fixd even t hough i dont have AC, and would a 00 si driver side motor mount fit? cuz i have an extra one.. or would LS driver side motor mount fit?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ph0shizzle »</TD></TR><TR><TD CLASS="quote">no.. gund my car few times after i got vtec installd
lol
that is very true. sorry for the misinfo, but yea oem is oem, hasport is hasport, but hasport>oem
lol
</TD></TR></TABLE>lol
lol
aaaaaahhhhhhh the god ol' timing belt motor mount......
Brings back so many memories!!!!!
I ripped that bad boy a few days after I installed an ACT clutch in an otherwise bone stock civic back in the day!
consider this breaking your cherry
haha yeah i broke that mount after i put my act 6 puck in. that has to be the worst motor mount design in the history of the world. now i have a shiney hasport mount in its place
TypeRod
Dec 7, 2011 02:45 PM
