Can't get rid of code 3 (MAP)
Old Feb 16, 2006 | 07:05 PM
pwr_crx's Avatar
Default Can't get rid of code 3 (MAP)
I have a d16a1 in my crx, I recently put a td04h in it. The MAP throws a code and runs the car in limp mode. The car is running so rich with the 450cc injectors it has in it. The car seems to be ignoring the Fields SFC in the car do to it running in limp mode.
I don't think the actual MAP sensor is malfunctioning, but another part of the system.
Anyone have any suggestions?
Old Feb 16, 2006 | 07:44 PM
beyondspexj's Avatar
you need to put in either some check valves ( using the fish tank filters from petsmart/petco ) or get a missing link. you can find those on ebay. your MAP sensor is seeing boost and that is why you car is running in limp mode and the CEL light is on.
Old Feb 16, 2006 | 08:48 PM
jisu009's Avatar
Default Re: (beyondspecs_jamar)
ditch the fields and get some TurboEDit
the stock MAP can read boost up to about 1 bar
Old Feb 16, 2006 | 10:01 PM
pwr_crx's Avatar
I can't use turboedit, i have a browntop d16a1 (vac-advance).
Im starting to think the fields is the problem
teg_95
Apr 28, 2009 07:19 PM
Btothe3rdDegree
Dec 2, 2004 08:52 PM
Cimburke23
Sep 13, 2004 05:23 PM
platinum00
Jul 25, 2003 09:16 AM
Turbo EG6
Aug 19, 2001 05:04 PM
