code 5. map sensor
Old Apr 28, 2009 | 06:08 PM
teg_95's Avatar
Default code 5. map sensor
im throwing the code for the map sensor. but im not sure exactly what it means. need to replace it? also how many pounds of boost can a stock map sensor hold. i heard ten the i heard 15.
Old Apr 28, 2009 | 06:38 PM
redflaredcrx90's Avatar
Default Re: code 5. map sensor
11 psi at most on a honda map if your running turbo. That codes means it seeing more the 11psi so time to change to a gm hondata or any bigger map
Old Apr 28, 2009 | 07:19 PM
teg_95's Avatar
i havent even boosted it yet. i had a phearable ecu in then i switch back to the non chipped one so i could send it in to be chipped for boost and it threw that code.
FSUseminoleEM1
Feb 19, 2010 08:34 AM
Kuppa
Sep 26, 2009 04:11 PM
eggie75
Apr 7, 2008 01:40 PM
FSS13foxtrot
Jan 20, 2008 06:23 AM
platinum00
Jul 25, 2003 09:16 AM
