How do you know when your engine isn't getting fuel?
Old Mar 27, 2002 | 10:12 AM
D1ANCER's Avatar
Default How do you know when your engine isn't getting fuel?
I just put a B16A1 into my EG and I burned 1/2 tank of gas in less than 60 miles, come to find out a hose on the intake manifold wasn't connected. I reconnected it and filled up to day to test out my MPG. But the wierd thing is when I turn the key to II(or on) and the cluster lights come on, there is no beeping noise like there used to be. Why is that? When I am at a stand still and launch, it takes a second for the car to really respond like it should. I am running my factory fuel pump with a 2000 Civic SI fuel feed line. What is the problem? What should I do?
Old Mar 27, 2002 | 10:14 AM
bigblockEG's Avatar
Default Re: How do you know when your engine isn't getting fuel? (D1ANCER)
get a rich/lean gauge. That will tell you where to go. You need one anyway if your going to mod the car.
Old Mar 27, 2002 | 11:40 AM
Kamin's Avatar
Default Re: How do you know when your engine isn't getting fuel? (Lil Cs Zc)
when the car is running does it smell like gas? it sounds like the map sensor.
my .02
Old Mar 27, 2002 | 06:05 PM
D1ANCER's Avatar
Default Re: How do you know when your engine isn't getting fuel? (KAMiN)
It does smell like gas, but it is not getting enough. I was told I was running lean. I have my DX MAP sensor hooked up to the motor, so what is the problem?
Psychoteen101
Sep 9, 2016 10:47 AM
likwidchz
Engine Management and Tuning
Nov 11, 2011 09:16 AM
cholder919
Oct 14, 2011 06:21 AM
eg6madness
Sep 19, 2007 12:28 PM
Powered By Garrett
23
Feb 17, 2007 12:47 PM
