Any of you guys have a non running cd player due to missing a ground behind the dash?
My cd player isnt working since putting my dash back on after taking the whole car apart for a rebuild. What ground did i miss back there that could be causing this, or rather what grounds are back there that i should check for? Thanks guys.
Hey. There is a ground near the steering wheel underneath near the center console be sure it's clipped on to the metal on the frame by the steering wheel . Also double check all of your harnesses. Good luck.
Nah that thing went haywire after a while. I tried to plug it up and blew the fuse. I know its a grounding problem cause when i touch a metal screw driver to the cd player and some metal it works.
I12BNU
14
Nov 6, 2008 10:02 PM
NiCkArInO
Aug 21, 2003 04:41 PM
