would i need to change my rods and piston to run a T3 turbo
Old Feb 14, 2006 | 09:32 PM
Got_EF8's Avatar
Default would i need to change my rods and piston to run a T3 turbo
yhea i need help finding out about me turbo charging my d16y6 v-tec. i would like to know if i need to change the rods and the piston's
Old Feb 14, 2006 | 10:16 PM
AJxr's Avatar
Default Re: would i need to change my rods and piston to run a T3 turbo (Got_EF8)
you dont need to if you are running under 8psi or so and have good compression in all the cylinders. if you want to run high boost (id say 10 and up) then you would want to get pistons and rods.
Old Feb 14, 2006 | 10:33 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: would i need to change my rods and piston to run a T3 turbo (AJxr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AJxr &raquo;</TD></TR><TR><TD CLASS="quote">you dont need to if you are running under 8psi or so and have good compression in all the cylinders. if you want to run high boost (id say 10 and up) then you would want to get pistons and rods.</TD></TR></TABLE>
what he said. no need under ~8psi.
Old Feb 14, 2006 | 11:29 PM
badboyr66's Avatar
Default Re: would i need to change my rods and piston to run a T3 turbo (sanimalp)
LOL... man... thiss like like "i am going autocrossing...dod I need a roll cage?" The real question is... how far down the rabbit hole do you wanna go? You will not be able to run any large amounts of boost, but you can run them just fine. And actually you can extract a decent amount of power with stock rods... the key is sin the tuning...timing ect. With just a FMU... yeah I would recomend about 8 lbs also. And a piece of advice...read everything you can
Old Feb 15, 2006 | 04:50 AM
DaX's Avatar
DaX
Loved
Community Favorite
I didn't on my B18A1, and it ran great! ...for only a year. I blew the headgasket once, then blew the headgasket again and spun a bearing on 8.5 psi.
It's great fun while it lasts, but it can be a ticking time bomb. If this isn't your daily driver, I say go for it.
Old Feb 15, 2006 | 04:54 AM
jdm91CrxSi's Avatar
Honestly I wouldn't turbo a d-series, one because as much as you spend on a turbo you could by a b16 and other is d series turbo w/ vtec don't get a long (experienced) but yeah you would need to get new p-rods and crank and cams if not that then cams but don't boost over 7psi -8 at max
Old Feb 15, 2006 | 08:19 AM
91CivicHatchback's Avatar
Default Re: (jdm91CrxSi)
d series engines dont like boost??not even true, people boost D's all the time and put out some nice numbers. as long as u have a good tune, which is the case with every engine that is boosted
Old Feb 15, 2006 | 09:17 AM
juice91si's Avatar
Default Re: (91CivicHatchback)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91CivicHatchback &raquo;</TD></TR><TR><TD CLASS="quote">d series engines dont like boost??not even true, people boost D's all the time and put out some nice numbers. as long as u have a good tune, which is the case with every engine that is boosted</TD></TR></TABLE>
Old Feb 16, 2006 | 03:32 AM
jdm91CrxSi's Avatar
Oh, i know some d series love some boost like d16a6 and y8 but some just dont like it
Old Feb 16, 2006 | 08:08 AM
Got_EF8's Avatar
thanks guys i bought crower rods and aeris low compression pistons also bout a watter jacket for the sleeve kit i bought for it but man all that **** cost me my arm,leg,ear, and left nut lol but hopefullyu it will run great amount of boost abd also i have a b18a1 that ime going all motor with ross pistons and crower rods.
Old Feb 16, 2006 | 08:46 AM
AJxr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm91CrxSi &raquo;</TD></TR><TR><TD CLASS="quote">but yeah you would need to get new p-rods and crank and cams if not that then cams but don't boost over 7psi -8 at max</TD></TR></TABLE>
maybe if he gets oem rods and stuff stay under 7-8psi. ive seen a d16z6 running 12 psi complete stock with 185k on it still running just fine till this day (going on 2 years). like everyone says its all in the tuning, and not getting cocky with boost. id say with rods and pistons you can run 10-12 psi, i dont know about anymore because of the stock sleeve issue. most people run 7-8 psi on all stock original internals, as its constantly said tuning is where it matters.
Old Feb 16, 2006 | 08:52 AM
Got_EF8's Avatar
yhea i bought the low compression pistons and the rods and the sleve kit and a water jacket to support the sleeves all i need now is some valve train any of u know anybody thats selling valve train for a d16y6 v-tec
Old Feb 16, 2006 | 09:02 AM
AJxr's Avatar
Default Re: (Got_EF8)
i have a whole d16z6 head/valvetrain/sensors/solenoid/valve cover, is that the head you mean? im not sure ive ever heard of a d16y6, not saying there isnt one though - i learn new stuff everyday
dont think id sell jsut the valvetrain though. whole complete head for $75 or trade, its in real good shape.
Old Feb 17, 2006 | 08:02 AM
Got_EF8's Avatar
no the head ime talking about is the D16Y6 that comes in the 1992-94 honda delsol SI and i need turbo high performance valve train not stock valve train
gibson_standard_sg
Sep 22, 2008 05:29 PM
civicb18Tkid
17
Apr 9, 2006 05:13 PM
altz
Feb 25, 2006 06:30 PM
Joel_MN
Aug 29, 2003 11:58 AM
Trajic
Jul 16, 2001 05:38 AM
