re use piston rings??
Old Feb 14, 2006 | 05:19 PM
KingOfQB's Avatar
Default re use piston rings??
wasnt sure where to put this got some spare b16 pistons on ls rods wanna throw in a lsvtec one rod snapped after were installed on origanal lsvtec, only about 30-40 miles were put on piston rings any one think these are still good?
Old Feb 14, 2006 | 06:50 PM
NJIN BUILDR's Avatar
Default Re: re use piston rings?? (KingOfQB)
Should be good for at least another 100k or so.
Glenn
Old Feb 14, 2006 | 06:57 PM
KingOfQB's Avatar
Default Re: re use piston rings?? (NJIN BUILDR)
ok thanx just need to replace rod then
Old Feb 14, 2006 | 07:04 PM
milton's Avatar
i reccomend new rings... for less issues in the future... pay 200 for new rings...
Old Feb 14, 2006 | 07:22 PM
highperboi's Avatar
yah rings are one time use only.
Old Feb 14, 2006 | 08:27 PM
KingOfQB's Avatar
Default Re: (highperboi)
but its just a spare block lol i dont want to put money into it
Old Feb 15, 2006 | 06:14 AM
slofu's Avatar
just be sure to use the same rings in the same bore, and try to keep the ring (gap) orientation the same.
Old Feb 15, 2006 | 06:47 AM
KingOfQB's Avatar
Default Re: re use piston rings?? (slofu)
yup same stock bore ok thanx
Old Mar 2, 2006 | 05:27 PM
EGmmBAH's Avatar
Well if the rings were installed correctly in the original LS-VTEC (which im sure they were not), and they were gapped in acordance to the block being used, then they are gapped for that block and if you put them in another block it will cause excesive smoking and significant loss of compression, make sure u gap you rings per block they are installed in and they are as stated above 1 time use only, thats almost as bad as re-using bearings! ! !
Old Mar 4, 2006 | 05:56 AM
PocketRockets Racing's Avatar
would you use used oil, doing an oil change?........
Old Mar 4, 2006 | 07:30 AM
98vtec's Avatar
moderator emeritus
Default Re: re use piston rings?? (EGmmBAH)
i'd get new ones just cuz....i mean its not like they are expensive.
GT500FTW
Jan 5, 2013 02:35 PM
got wide
Sep 4, 2007 03:55 PM
Kr4nG
Mar 13, 2007 10:48 PM
xteg95
May 3, 2003 04:16 PM
wrXtian
Apr 9, 2003 08:39 AM
