car shakes
Old Feb 14, 2006 | 01:30 PM
eg4metodrive's Avatar
Default car shakes
eg with swap and the car shakes when im around 2500-3k rpm also pulls to the left when i gas it
Old Feb 14, 2006 | 01:32 PM
Shake and Bake's Avatar
Sounds like your alignment is fucked. Are you tires balanced?
Old Feb 14, 2006 | 01:38 PM
Default Re: (AllstockSIke)
alignment it is thanks for the help
Old Feb 14, 2006 | 02:42 PM
schardbody's Avatar
alignment wont cause a shake or a pull when accelerating. broke motor mounts/tranny mounts will cause torque steer which sounds like what you are experiencing. if the shake is at certain RPMs like you explain check the crank pulley for being bent, also have your axles checked out, if the inner tri-pod has just a little play it will cause your shaking and pulling when accelerating.
Old Feb 14, 2006 | 02:55 PM
strictly.business's Avatar
Banned
without an lsd tranny, torque steer is noticed with perfectly good motor mounts. the torque steer is normal, what gear are you in when it shakes? if youre on the freeway in 4th or fifth gear at 3k, your alignment may need to be set and your wheels may need balancing.
Old Feb 14, 2006 | 02:56 PM
JDM-EJ1's Avatar
Default Re: (schardbody)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schardbody &raquo;</TD></TR><TR><TD CLASS="quote">alignment wont cause a shake or a pull when accelerating. broke motor mounts/tranny mounts will cause torque steer which sounds like what you are experiencing. if the shake is at certain RPMs like you explain check the crank pulley for being bent, also have your axles checked out, if the inner tri-pod has just a little play it will cause your shaking and pulling when accelerating.</TD></TR></TABLE>
More than likely this. Also, could be the alignment as well.
Old Feb 14, 2006 | 04:57 PM
Default Re: (strictly.business)
tranny does have lsd also when im rolling car rides straight but only when i gas it pulls left and starts to shake almost in every gear 2500-3k when i go about 65+ i can feel it too on the freeway thanks for the help guys need to get this fixed
Old Feb 14, 2006 | 05:09 PM
Syndacate's Avatar
it sounds like a motor mount or tranny mount, but if it's STOPPING at 3k, that isn't a motor mount. Have a 4 wheel alignment done anyway though, that can easily cause problems, I don't know what's causing that pull problem though :-\
Old Feb 14, 2006 | 05:18 PM
cisurfer1's Avatar
We had the same problem there was somethign wrong with the one axle, so check those
Old Feb 14, 2006 | 05:37 PM
schardbody's Avatar
im trying to tell you that an alignment wont cause a shimmy/shake/vibration. 90% of the customers that come to my shop for an alignment say they need it for a shimmy in the wheel, and it never fixes it. almost 100% of the time tire/wheel related. get an alignment if you want but dont expect anything to change.
Old Feb 16, 2006 | 03:34 AM
Default Re: car shakes (eg4metodrive)
driver side axel was the problem!!!!
Old Feb 16, 2006 | 09:45 AM
schardbody's Avatar
your welcome
Old Feb 16, 2006 | 09:49 AM
93preludeh22's Avatar
My car was shaking like crazy accelerating (around 2000-4000rpm... (I have to guess because I don't have a tach))
I got an alignment and it fixed the crazy vibration accelerating
(H22 in 95 Hatch)....
Old Feb 16, 2006 | 11:25 AM
bo0stedk2o's Avatar
alignment or tire balance
Old Feb 16, 2006 | 12:29 PM
schardbody's Avatar
if you say so..... but in my 6yrs of professionally doing alignments, brakes, suspension for a living (among other things) i have found there is NO POSSIBLE WAY AN ALIGNMENT CAN CAUSE A VIBRATION. sorry
Old Feb 16, 2006 | 12:30 PM
schardbody's Avatar
oh i should say if the alignment shop or whatever seen a more worn tire or whatever and swap it to somewhere else on the car that would have taken care or atleast made the vibration less noticeable.
Old Feb 17, 2006 | 02:47 AM
Syndacate's Avatar
can't believe I didn't see that it was the axle, I had the same problem in my probe awhile, it would pull to one side (forgot which) and it vibrated - I dued it to the fact that a rim was bent on that side, but after I replaced it, it did nothing, so I put it up on a lift and I noticed all the fluid coming out of the axle boot, replaced the axle boot (and the lower A-Frame was messed up to replaced that too) and it was fine...
O.O
csoares
Transmission & Drivetrain
Apr 18, 2013 08:38 AM
bodiez
27
Apr 24, 2009 05:16 AM
champLSinteg
Mar 14, 2008 01:28 PM
DarkCyde SI
May 23, 2003 10:33 PM
