3-ans big enough for oilcooled turbo?
Old Feb 14, 2006 | 08:48 AM
SpoolnByYou's Avatar
Default 3-ans big enough for oilcooled turbo?
sup guys,
car is smoking some at idle and while warming up. someone told me to go with an oil restrictor,to a 3-ans fitting. so i went from a (i think its a 1/8" hole) to a 3-ans oil restrictor feed fitting. is this going to be big enough to cool the turbo,since its oil cooled? is 3-ans what most oil cooled turbo people run?
Old Feb 14, 2006 | 09:39 AM
Default Re: 3-ans big enough for oilcooled turbo? (SpoolnByYou)
anyone?
Old Feb 14, 2006 | 09:40 AM
D@nnY's Avatar
-3 line is plenty big turbos do not use alot of oil
Old Feb 14, 2006 | 09:50 AM
Chris22215's Avatar
Default Re: 3-ans big enough for oilcooled turbo? (D@nnY)
and make sure your oil drain is going as straight down as possible
Old Feb 14, 2006 | 10:13 AM
Default Re: 3-ans big enough for oilcooled turbo? (Chris22215)
but even for a oil cooled turbo? i mean its going to be enough oil to keep it cool?
Old Feb 14, 2006 | 10:15 AM
EJ1 wilcox's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoolnByYou &raquo;</TD></TR><TR><TD CLASS="quote">but even for a oil cooled turbo? i mean its going to be enough oil to keep it cool?</TD></TR></TABLE>
It's not really "oil cooled", the oil just lubricates the bearings. The oil is pretty hot when it hits the turbo.
And yes, -3an will work fine. That's the size that pretty much everyone uses.
Old Feb 14, 2006 | 10:52 AM
cobra2326's Avatar
Default Re: 3-ans big enough for oilcooled turbo? (EJ1 wilcox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1 wilcox &raquo;</TD></TR><TR><TD CLASS="quote">It's not really "oil cooled", the oil just lubricates the bearings. The oil is pretty hot when it hits the turbo.
And yes, -3an will work fine. That's the size that pretty much everyone uses. </TD></TR></TABLE>
It is oil cooled. Thats why you have to leave you engine running after you drive your car. The oil carries the heat away from the turbo bearing so they dont "coke" up.
Old Feb 14, 2006 | 11:06 AM
nonvtecD's Avatar
I'm using 3 an line on my oil cooled t3, you're fine
Old Feb 14, 2006 | 11:28 AM
EJ1 wilcox's Avatar
Default Re: 3-ans big enough for oilcooled turbo? (cobra2326)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cobra2326 &raquo;</TD></TR><TR><TD CLASS="quote">It is oil cooled. Thats why you have to leave you engine running after you drive your car. The oil carries the heat away from the turbo bearing so they dont "coke" up.</TD></TR></TABLE>
Ehh.... I guess in that respect you could say that it cools the turbo.
The oil cokes if it sits in the hot turbo for an extended period of time. But, I still don't think the oil really does any significant cooling at all. I'll have to read back through Maximum Boost I guess.
I never left my engine running after running my turbo hard. Of course, I had a water cooled turbo. When I rebuilt my turbo after a year of abuse and no cool down time, there were zero signs of coking. The bearings looked perfect.
Anyways, that doesn't really have to do with this thread I guess.
Old Feb 14, 2006 | 05:31 PM
D@nnY's Avatar
lubricates is more like it
hondaPSi
Apr 11, 2006 05:16 AM
Cee_mon
Nov 18, 2005 06:11 AM
JLman86
Jul 12, 2005 11:44 AM
