Manual Boost Controller Installation?????????
just bought me a Manual Boost Controller and hopefully it will help me on adjusting the certain PSI that i want to run on my Accord. It is a MBC and there are two stickers on each side says SRP. Don't know if you guys familiar with that. Anyways it is equipped with ball spring to reduce Tubo lag and here's the website:
http://cgi.ebay.com/ebaymotors...spage name=STRK%3AMEWN%3AIT&rd=1
I also received an instruction but just want to double check with y'all opinions. The nipple as shown at the bottom, it says to connect to Wastegate (i'm using 38mm and there's a Nipple at the very top of it), so i'm assuming that's where i need to connect to. But the straight nipple says to connect to Boost Source (is that to a Vacuum Source???) like connect to the Intake Manifold or BOV etc?????
boost source goes to compressor housing, charge piping, or intake manifold
wastegate goes to the BOTTOM (side) port on the wastegate. Not the top one.
are you sure??? Cause i thought the bottom one goes to the Turbo and that's what every says too...well, if i use the bottom nipple for boost controller, then what about the top???what's it for?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Azndude1983 »</TD></TR><TR><TD CLASS="quote">are you sure??? </TD></TR></TABLE>
yes!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Azndude1983 »</TD></TR><TR><TD CLASS="quote">Cause i thought the bottom one goes to the Turbo and that's what every says too...well, if i use the bottom nipple for boost controller, then what about the top???what's it for?</TD></TR></TABLE>
the bottom one does go to the turbo. you put the boost controller in line with it. the top one's for an electronic boost controller you leave it open with an MBC.
trust me I know a little bit about this stuff.
yes!!!
Silva Bullit DC4
Jan 17, 2008 02:06 PM
boost, connect, controller, ebay, honda, hondatech, install, installation, installing, instuctions, manual, srp, trust
