Hallman manual boost controller problems
Old Aug 15, 2002 | 08:15 PM
B20LS-T's Avatar
New User
Default Hallman manual boost controller problems
I purchased a hallman boost controller and I cant seem to get it lower than 10 psi. I hooked the top port of the tial wastegate to the side of the BC then the bottom nipple of the BC to the I/c piping going to the compressor housing(I tapped a hole in it). Did I hook up the controller wrong? do I need to disconnect side port of my WG, or do I keep it connected to a vacuum source? I have the **** on the BC all the way out and it still reads 10psi. Any advice as to what to do?
Old Aug 15, 2002 | 09:09 PM
Smashback's Avatar
Default Re: Hallman manual boost controller problems (B20LS-T)
because the top port of the w/g should be open.....the mbc should go between the side port of the wg and the vacuum source.
Old Aug 15, 2002 | 09:23 PM
B20LS-T's Avatar
New User
Default Re: Hallman manual boost controller problems (mplex2000)
Are you sure? It makes sense, but what is the top port used for? There is a fitting that was given to go there so it must have an use?
Old Aug 15, 2002 | 10:30 PM
shadowdawn's Avatar
Trust me I use the joe mbc (nearly the same thing) it works like the man said, side port of wg ONLY (leave top open) and then the other port on the mbc to the intake manifold (works better this way I think since IM will cut out pressure drop that happens before the throttle plate)... Tap it off your IM -> FPR vac line or before the check valve in the brake booster, either works fine.
Old Aug 15, 2002 | 10:41 PM
TriK's Avatar
Default Re: Hallman manual boost controller problems (shadowdawn)
ok!.. i have to understand,,
my wastegate have 2 hole.. i plug one hole with a Main vaccum.. and the other with my MBC
you say it's better to put the MBC on the Main vacuum port?
Old Aug 15, 2002 | 10:46 PM
Smashback's Avatar
Default Re: Hallman manual boost controller problems (TriK)
That's the correct way to do it. The top port should be open unless using an EBC which will use both ports.
Old Aug 15, 2002 | 10:50 PM
TriK's Avatar
oH! maybe its WHY it's lagging and the boost are not very regular (depent on the temperature) ??
i will try that tomorow thanks!
SO MBC on betwin vacuum port and intake manifold and i left the top port Open
Old Aug 16, 2002 | 01:49 AM
B20LS-T's Avatar
New User
Problem fixed...hooked it up like you said and it works beautiful...thanks!
Old Aug 16, 2002 | 12:40 PM
TriK's Avatar
i hook my mbc like that...
my mbc are made from a ajustable compress air ( garage thing) it's that work?
prezioso01
Mar 18, 2016 03:54 PM
samuraijackass
Nov 25, 2009 06:01 PM
Silva Bullit DC4
Jan 17, 2008 02:06 PM
BoOsTiN Dc2
Apr 26, 2004 07:24 AM
_Shadow_
Oct 19, 2002 05:38 PM
