V-Tec Conversion for B18B1
Old Feb 12, 2006 | 11:08 AM
kyteggy's Avatar
Default V-Tec Conversion for B18B1
so i have been looking around on this site to see if this post has already been answered but i couldnt find it. so if you guys have answered this a billion times i am sorry.
so i found an integra type r head online and i want to put it on my stock b18b1 block. now i kno i have to run new oil lines for the vtec and also power to the solenoid. if anyone has done this and can assist me in any way it would be awesome.
i need to kno where to get the power from and how to set up the oil lines?
THANKS
DAVE
Old Feb 12, 2006 | 11:15 AM
sirg-vtec's Avatar
Default Re: V-Tec Conversion for B18B1 (kyteggy)
I don't know anything but I do know that this topic has been covered many times. The "scene" call this method, LSVTEC. Why? Because LS motor have more torque than a regular gs-r motor. The gs-r motor on the other hand, has more top end than the LS. Therefore, putting a vtec head on a non vtec block will create the best of both world.
Ignore my mumbling above. Golden eagle sells a ls/vtec kit. Check that out.
http://www.accountwizard.com/c...lemfg
check this out?
http://www.team-integra.net/fo...earch
Use the search function?
sorry. I just wanted to post something. I know more about quantum mechanics than i know about lsvtec.
Old Feb 12, 2006 | 01:15 PM
nickG's Avatar
its called an lsvtec
search the archives for it...search through the 10000 threads like yours and eventually youll find one thats informative
Old Feb 12, 2006 | 01:21 PM
.brian.'s Avatar
Default Re: V-Tec Conversion for B18B1 (sirg-vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sirg-vtec &raquo;</TD></TR><TR><TD CLASS="quote"> LS motor have more torque than a regular gs-r motor. </TD></TR></TABLE>
1994-2001 Integra
Torque (lbs-ft), SAE net
LS/GS/RS - 127 @ 5200 RPM
GSR - 128 @ 6200 RPM
TypeR - 130 @ 7000 RPM
Old Feb 12, 2006 | 01:22 PM
ecks_fourttwo's Avatar
this is either the fourth of fifth thread lsvtec question thread that ive seen within the last 4 hours
Old Feb 12, 2006 | 01:26 PM
.brian.'s Avatar
Default Re: (ecks_fourttwo)
here are some links that should prove to be pretty helpful if you take the time to read through them....(taken from the integra FAQ thread, found at the top of the integra forum)
https://honda-tech.com/zerothread?id=1119323
https://honda-tech.com/zerothread?id=1082172
https://honda-tech.com/zerothread?id=1083788
https://honda-tech.com/zerothread?id=501372
https://honda-tech.com/zerothread?id=720621
https://honda-tech.com/zerothread?id=805408
Modified by .brian. at 6:42 PM 2/12/2006
Old Feb 12, 2006 | 02:39 PM
98IntegraLSNonVtec's Avatar
Default Re: V-Tec Conversion for B18B1 (.brian.)
» Search Results
Your search for LS VTEC returned 615 results
Maybe you couldn't find any because VTEC doesn't have a "-" in it.
Old Feb 12, 2006 | 03:55 PM
nickG's Avatar
Default Re: V-Tec Conversion for B18B1 (98IntegraLSNonVtec)
check this out
https://honda-tech.com/zerothread?id=1519455
fickel_8
Nov 2, 2005 12:24 PM
shinji666
Aug 20, 2004 12:22 AM
jackal99a
Aug 13, 2004 08:07 PM
DrewQ1
Jul 16, 2004 12:41 AM
gsx0r
Sep 15, 2001 01:33 PM
