Dyno results 7 psi custom kit: 266.4 whp(dynojet)
Old Feb 11, 2006 | 12:15 PM
calvinPGMFI's Avatar
Default Dyno results 7 psi custom kit: 266.4 whp(dynojet)
I had my car on the dyno today.
Boost level was 7psi.
I pulled 266.4 whp @ 222.9 NM(165.3 ft-lbs)
fully built b16a2 1.6L darton/eagle/probe
edelbrock victor x
70mm tb
gsr cams
t3/62-1 turbo
3 inch downpipe 2.5 inch exhaust
tail 44mm wg
tail 50mm bv
full-race piping
full-race manifold
backdoor intercooler
racimex oilcooler
thik JDM radiator
Stock ignition
After 15 dyno pulls the IAT temp got to high i had no time to adjust iat vs fuel table. The AFR over the full rpm range got richer and killed my whp.
for my full setup see http://www.cjperformance.com
lease comment this dyno sheet:
Modified by calvinPGMFI at 10:28 PM 2/11/2006
Modified by calvinPGMFI at 10:32 PM 2/11/2006
Old Feb 11, 2006 | 12:21 PM
Dunc's Avatar
BCICAN
Default Re: Dyno results 7 psi custom kit: 266.4 whp(dynojet) (calvinPGMFI)
I would definitely hope your A/F is alot richer than that. Not bad other than that
Old Feb 11, 2006 | 12:22 PM
atec's Avatar
Nice to see that hp on low boost..
going to dyno with more boost or stick with 7psi?
Old Feb 11, 2006 | 12:31 PM
I will open boost shortly to 15-20 psi.
AFR on my plx was 12.0-12.5 this is on 98 octane(ron fuel).
CJ
Old Feb 11, 2006 | 12:40 PM
chrisgottigsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by calvinPGMFI &raquo;</TD></TR><TR><TD CLASS="quote">I had my car on the dyno today.
wouldnt that be restrictive? 3 inch downpipe to 2.5 inch exhaust.
Old Feb 11, 2006 | 12:52 PM
Default Re: Dyno results 7 psi custom kit: 266.4 whp(dynojet) (chrisgottigsr)
next time i will use an open downpipe.
CJ
Old Feb 11, 2006 | 01:23 PM
B18 CYA's Avatar
holy lag
Old Feb 11, 2006 | 03:40 PM
Importracer_001's Avatar
I think that your A/F should be a richer and IMO that turbo is too big for 1.6l displacement
but otherwise great set up!
Old Feb 11, 2006 | 03:48 PM
MidShipCivic's Avatar
Default Re: (B18 CYA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18 CYA &raquo;</TD></TR><TR><TD CLASS="quote">holy lag</TD></TR></TABLE>
Spool looks nice to me.
Old Feb 12, 2006 | 09:19 AM
boosted k20's Avatar
Default Re: (MidShipCivic)
that spool dont look good to me. 200whp by 6500 rpms!!!!! he should be at 200 whp at like 4.5-5K. turbo is too big for that setup.
also u need to make ur a/f richer. shoot for 11.6-11.8 for safe tune
Old Feb 12, 2006 | 10:03 AM
Drag_On's Avatar
What the hell could you possibly need a 62-1 on a stock bore B16?
Talk about over-turboing it.. I never understand why people think that
peak power &gt; fat powerband..
"Traction"... Blah.. get some tires and learn how to drive..
Nice power numbers - way too much lag..
Old Feb 12, 2006 | 10:11 AM
raene's Avatar
Default Re: (Drag_On)
Maybe he's only interested in drag... not everyone cares about spool point y'know (myself included)
Nice #s, I love how you can see the tq jump up
Old Feb 12, 2006 | 10:39 AM
Semnos's Avatar
Nice power.
He already said on his PLX the A/F was 12-12.5
or his PLX is giving him wrong readings or the WBO2 in the muffler from the dyno shop is.
With 7 psi boost 200 whp@ 4.5-5K would be difficult to get.
Graph looks good and the lag looks like most setups on HT.
Old Feb 12, 2006 | 12:52 PM
Default Re: (Semnos)
I ordered a 60-1 but their is written 62-1 on the turbo. So i have one of both.
This only 7psi. I will open boost shortly to 15 psi.
Maybe in the future i will upgrade to 84.5 mm pistons.
CJ
Old Feb 12, 2006 | 02:17 PM
lucidvtec's Avatar
what compresson u runnin??
Old Feb 12, 2006 | 02:39 PM
Default Re: (lucidvtec)
9.4
Old Feb 12, 2006 | 02:43 PM
.nate's Avatar
Sweet
19slocivic97
May 23, 2009 04:32 PM
civicjdmb16a
Oct 2, 2007 08:59 PM
VTC_CiViC
Feb 25, 2004 09:24 PM
92HB_HB
Oct 2, 2003 03:17 PM
