b16 heat prob
Old Feb 11, 2006 | 06:10 AM
user 25438239's Avatar
Default b16 heat prob
okay, i put a brand new oem thermostat in my b16a (1st gen in a 90 crx). when car is just ideling (not moving), it wont over heat. but when i drive it, it gets hott. like criticaly hot. here is the weird part. if i turn temperature **** for my vent all the way to heat, the temp will go back to normal. if i have it on cold, it will get hot again. WHAT THE F IS CAUSING THIS!!! PLEASE HELP
Old Feb 11, 2006 | 07:34 AM
white91rex's Avatar
Default Re: b16 heat prob (JCrimson)
It sounds like you have a blockage in your radiator or lines, Or possibley a bad fan? When you turn the heat on it opens up your heater core and coolant flows thru it, it acts is a seconed radiator and thats why the temp drops. Check over your cooling system, water pump, hoses and the radiator.
-chris
Old Feb 11, 2006 | 08:07 AM
nice thanks chris. problem is, this is a new aftermarked radiator i got like 1 year ago and the water pump is brand new oem. it was installed before my swap back liek 4 months ago.
Old Feb 11, 2006 | 08:08 AM
fan is switching fine btw
Old Feb 11, 2006 | 08:51 AM
i hate rice's Avatar
Default Re: (JCrimson)
you probably need to bleed your coolant
Old Feb 11, 2006 | 08:53 AM
i already left the car running for like 30 mins with the cap off. its this the propper way?
Old Feb 11, 2006 | 09:02 AM
Hondacivic90ed's Avatar
check the radiator itself, it may look fine where it is, but if you look at the fins inbetween the actual coolant lines in the radiator, see if they are corroded or falling out or even missing. They acutally play an important role in the radiators efficiency by increasing the surface area of the fins. Since they are usually made of copper on a stock radiator they corrode and break and fall out of between the cooling fins. This happened to my 92 si hatch, I replaced the radiator and thermostat and the problem went away.
Old Feb 11, 2006 | 09:13 AM
this exact same problem happened to you?
Old Feb 11, 2006 | 11:57 AM
yes, not in the same engine/car, but the same example basically, I bought the car and not long after it started to run very hot, so i would drive around w/ the heat on to keep the coolant level from boiling and overheating the engine. I replaced the thermostat with no change, so I replaced the radiator and the problem went away, the radiator was shot, not leaking but the fins were almost all gone or falling out.
Old Feb 11, 2006 | 04:37 PM
white91rex's Avatar
Removing the rad cap may bleed the air out but it is not the correct way. You have a bleeder screw on your thermo housing, you open it a few turns and run the engine into coolant comes out.
-chris
dirty5outhazn
Mar 20, 2012 04:07 PM
prodragEG
11
May 11, 2010 08:34 PM
11secteg
Apr 6, 2007 06:13 PM
streetracerof06
Dec 8, 2005 03:03 PM
bigslimdog
Aug 10, 2004 03:37 PM
