map sensor wiring
Old Feb 11, 2006 | 01:40 AM
seanclark's Avatar
Default map sensor wiring
hi to start off im from the uk ! im am doing a engine conversion on my eg civic, it used to have a d16z6 engine in and im converting it to a b16a2 engine
on the d16z6 engine over here the map sensor is on the throttle body and wired in through the main engine harness ! but on the b16a2 for the eg it is mounted on the firewall with a seperate wiring harness, now i didnt get the map sensor or wiring with the engine so can i use the map sensor off my d16z6 ? also how do i wire the map sensor in ? which wires goto where etc. ?
Old Feb 12, 2006 | 07:24 AM
seanclark's Avatar
Default Re: map sensor wiring (seanclark)
anyone have any idea ?
Old Feb 13, 2006 | 12:25 AM
MrMike's Avatar
attatch the map sensor from the D16 with a vacuum hose to one of the vacuum ports on the B16 throttle body. Use your D16 wiring harness and plug it in.
Mikes2000civicsi
Jun 4, 2011 09:02 PM
raleylund
Oct 18, 2007 12:29 PM
92ehatch
Oct 15, 2006 06:16 AM
SOHCEK-Turbo
Oct 16, 2003 09:42 PM
