does the obd1 d16z6 have a knock sensor?
ok, thats why im getting a code 23 when the swap was done. does anyone know the pin on the gsr ecu that the knock sensor goes into. im going to try and wire one in today.
thanks, but im going to have to wire a wire in there because we are using the d16z6 wiring harness that does not have that wire?
if you look at the back of the plug you will see that there is a keeper at the top and bottom of the plug that clips to the side plastic. doesnt take much force but these will pop and fold up on the plug, then you have access to the pins and can pull them out with relative ease.
beginmyhonda
Jul 29, 2009 02:14 PM
phanatic
May 18, 2007 02:21 PM
hj
Oct 29, 2003 04:40 PM
