clutch stuck to the floor again
i woke up today to go to school and my clutch pedal was again stuck to the floor. last week the same thing happen and i put more fluid in the master cylinder and i blead the system and everything was fine . today its back stuck to the floor . so there is a leak in the system somewere im assumiing . well i popped my hood and there is fluid coming out somewhere from right under the distributer and around the valve cover some where i havent been able to locate the leak. i would like to know if any knows were a line are a seal that could be leaking some where in that area thanks for any help i get back .
Maybe around the soft line that connected to the slave cylindar? I would also double check that all the peices of the hydraulic line that run from your clutch resovir are tightened down securely.
S2Integra
Transmission & Drivetrain
Mar 20, 2010 06:42 PM
NONKonformyst
Dec 15, 2002 11:01 AM
