Help Car wont start, could it be immobiliser ?
Old Feb 10, 2006 | 01:59 AM
Kavehman's Avatar
Default Help Car wont start, could it be immobiliser ?
Hi I have an aftermarket immobiliser on my car which has an open circuit.
I know the immobiliser is connected to my starter.
Now my car wont start, it cranks and i get a clicking sound but no spark, so I'm wondering if my immobiliser would allow cranking but no spark.
Maybe a stupid Q but any help ?
Old Feb 10, 2006 | 04:12 AM
B18C_EJ8's Avatar
You need to look and see which circuit they interrupted when they installed the immobilizer. If they cut your ignition wire, the starter will still crank.
Old Feb 11, 2006 | 11:01 AM
fcm's Avatar
fcm
Old Fart
Default Re: (B18C_EJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">You need to look and see which circuit they interrupted when they installed the immobilizer. If they cut your ignition wire, the starter will still crank. </TD></TR></TABLE>Ditto the above. the also make 2 and 3 point immobilizers, so more then one point can be immobilized.
Let me ask you this, when you turn on the ign. and/or try and start the car, do the cluster instruments, [gauges and warning lights] come on, can you hear the fuel pump relay "click" on and the fuel pump run for a sec. or two, [priming the fuel line] when you turn on the ign.?
Let us know. 94
loayo
11
Mar 12, 2012 12:49 PM
haze808
Jun 25, 2010 04:16 PM
yourheero
May 6, 2009 11:14 AM
Fresh Ej2
26
Apr 2, 2009 06:19 PM
SiSoul
May 31, 2003 12:08 AM
